Question about Husqvarna Garden
I have a husqvarna 125b gas blower and it came missing its manual. Can you explain the high and low speed idle controls : which is which and what is used to adjust them Thanks
  • Husqvarna Master
  • 2,239 Answers
A special tool is required to adjust the carb screws, it should be set up from the factory for the best emmissions, so there should be no need for you to adjust them, however the L screw controls the low speed and acceleration up to half throttle, the H screw controls the max rpm, the the third screw just controls the idle speed, if you need the tool it is part no. 530035560, both screws are fuel, not air screws, screw the L screw in until you get the highest revs, then back it out 1/4 turn, screw the H screw in for the highest rpm, now back off 1/4 turn. if the machine does not pick up smooth increse the L screw bit at a time until it does, if the full revs sound too rich, screw the H screw in a very tiny bit.
Posted on Mar 31, 2011
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
My backpack gas leaf blower cranks no problem, But then won't come up to full speed. I have diassembled and cleaned everything possible and replaced the spark plug. Each time it improved for a short time....
Try adjusting the high and low screws to the carb when running make small adjustments. Adjust the low when Idle and the high when giving throttle.
Oct 31, 2013 | Husqvarna Garden
I need to know the starting point and how may turns to adjust the high/low speed carb screws. I have the tool. but no in fo.
Both screws start at 1 turn out....Adjust High speed till it 4strokes and 2 strokes usually 1/8 turn either way....then adjust idle so it revs staight up...should be same 1/8 turn either way from start...if it is more carby will need overhauling..
Oct 09, 2013 | Husqvarna 125B Blower
When I prime my Husqvarna 125b the gas pours out little vent hole next to the fuel lines going into gas tank? Dont think any gas getting to carborator?What would cause this?
1. Check the pipes to the primer bubble haven't been swapped round, as it sounds like its pressurising the fuel tank.
2. Also sounds like the fuel tank vent could be damaged, this allows pressure to equalise in the fuel tank. Generally it allowa air in but not out the tank, If fuel is exiting the tank then this could have been damaged.
Apr 12, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Nov 22, 2009 | Husqvarna Garden
Garden Logo
238 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
