Question about Epson PowerLite 7300 Multimedia Projector
Am I correct that most ghosting issues require replacing a part?
    Problem Solver:
  • 6 Answers
It is possible you would need a replacement part. Check your cables first though. Many ghosting issues can be caused by a bad cable or connector. Additionally if your signal is coming from a computer you can try using a different input connection.
How long is the cable running from your source?
Posted on Mar 31, 2011
Ghost blue line with a curve
I'm sorry that the TV is displaying ghost blue line with a curve in the screen. Please follow the troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper.
Try connecting a different video source like DVD player or VCR and check the operation.
If it works with another device, the issue might be with the input device currently.
Also try connecting the device to a different port in the TV if no other devices are available.
If the issue persists, try with a different cable.
Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup a service for the TV.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Sep 05, 2011 | Samsung PCL545R 54" Rear Projection...
My HP Laserjet P2055dn prints out with a shadow of everything printed.
The ghosting is caused by the fuser assembly. The main user roller has a Teflon coating that keep the toner from sticking, when the coating wears off you start getting the ghost printing like you are having. You can get replacement fusers online from many sources, just do a Google search for P2055DN Fuser. They are user replaceable, only requiring a Phillips screwdriver to replace.
I hope this helps, if so please rate my solution.
BuddyMc
May 08, 2011 | Office Equipment & Supplies
I DO NOT KNOW HOW TO REINSTALL THE M.S.OFFICE FROM GHOST FILE IN HARD DISC.
If you are using "Norton Ghost" then it is similar to a standard backup/restore programme.
Open Ghost, select all of the files you require, if it is a programme that you want then you must include the Windows directory and System 32 directory as there are files the computer requires to register the programme again.
Usually Ghost is used to replace all of your data on the hard drive.
If you have additional files that you wish to keep, backup those files first, then you can add them to your recovered hard drive.
Hope this helps.
Oct 22, 2010 | Microsoft Computers & Internet
Samsung HCP4752W convergence board?
I couldn't decide whether or not to attack the IC Chips or the whole board, so I took out my S&W model 59 and pumped 11 9mm rounds into the whole chassis! Sets works as new as long as 'new' means comes with 11 bullet holes in chassis.
May 12, 2009 | Samsung HLN437W 43" Rear Projection HDTV
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Apr 30, 2009 | Computers & Internet
Convergance issue on one AV input only
This is not a convergence problem in the traditional sense as it would effect all inputs not just one. I would be looking at the video switching IC as the defective part. I'll look up your model to try to get you more details. Are you going to attempt the repair yourself?
Thanks,
Dan
Jan 05, 2009 | Sony KDF-50E2000 50" HDTV
Removing norton ghost before reinstalling
If you tried removing Ghost yourself by deleting foulder or files then it will not appear in the add/remove list. Try reinstalling it and then using removal tool. Make sure you have correct one for version and your OS. My advice is stay away from Norton products, they severely slow down performance and hinder daily activities. There are free tools online that work much better.
Dec 30, 2008 | Symantec Norton Ghost 14.0: Windows
Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Sep 17, 2008 | Office Equipment & Supplies
Blue ghost on left side of screen only when on hi def channels
hello its sound like you need to replace the (IC chip) for your blue (CTR gun) .!!! its going bad.!!!hope this help's you ."good luck"
Jul 19, 2008 | GE 46GW947 46" Rear Projection Television
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Epson PowerLite 7300 Multimedia Projector Logo
330 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
