Question about Amana ACF4265 Electric Kitchen Range
The range is brand new. After making a pie (which spilled over) I cleaned up most of the spill. I decided to turn on the self cleaning. The oven was on about half an hour when the house was filling with smoke. My eyes were burning, and I couldn't breath. I turn the oven off, and left. Later when I came back where the controls are the oven is yellow, and I can't get it off. I have tried the cleaner that came with the oven, windex, baking soda, dawn dish soap. Does anyone have a suggestion as to what else I could use? Thank You, Andy
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
Maanita
  • 1142 Answers
SOURCE: Can't use oven, displays CLN
Can you please give some more detail to assist you better
Posted on Apr 08, 2008
SOURCE: amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Posted on Nov 17, 2008
taran_2005
  • 10515 Answers
SOURCE: Self clean oven door wouldn't unlock!
Try a trick that was given by an expert :-
All I needed to do was unscrew the 2 screws holding the lock assembly and it released it!! I screwed it back in and set the oven to self clean and it worked!!
Unless , F9 refers to slave micro not working. A condition in which you might need to replace control board.
Thanks.
Posted on Jun 04, 2009
  • 351 Answers
SOURCE: I owe a ACF4255A. I
something may have spilled in the oven and that what smoking
Posted on Sep 29, 2010
What should I do to clean my oven?
You can use Easy Off 'Fume Free' oven cleaner on a self-cleaning oven, if you want to manually clean it, but do not use it with the self-cleaning cycle.
Apr 26, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire electric stove
Hello friend, thank you for your post!
If you had an over spill in the back of your Frigidaire oven it could have possibly shorted out the terminal block or control panel. I would recommend cleaning any access spill and contacting a professional to come out and verify no additional internal damage has been done to the appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
My oven is smoking excessively during self clean. I have only used it to bake twice and was just trying to clean off two small blobs of cheese from a frozen pizza. This was my first time to use the self...
Could be because it's new. You can buy an oven liner for the bottom to catch the spills. Also there is a product out that is safe for spot cleaning a self cleaning oven.
Mar 16, 2010 | Frigidaire FGF368GM Kitchen Range
Spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Dec 31, 2009 | Kitchen Ranges
How to set up for self cleaning oven
The first time you do a self clean it does smell weird and you setthe time to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven
Sep 22, 2009 | Dishwashers
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Atlas La Stella double oven
Hello Roland,
happy to help you out!
You must clean by way of wiping excess spills and materials dripped or spilled before self clean is operated. Or there will be smoke even during the self clean process!
Also do not wait till there is build up galore to self clean your oven!
If you spill or splatted and drip in the oven that day,
start the self clean after you do the dinner dishes!
More info can be found int he owners manual!
Aug 24, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Open Questions:
See all Amana ACF4265 Electric Kitchen Range Questions
Amana ACF4265 Electric Kitchen Range Logo
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
