Question about Health & Beauty
I PURCHASED A USED PRIDE JET 12 POWER CHAIR .MY QUESTION IS THE MANUAL SAID THAT TO OPERATE IT I HAVE TO TURN IT ON .WHERE DO I TURN IT ON IS THERE A KEY /SWITCH THAT I MISSED
  • 692 Answers
On the top of the joystick in front is a decal button with I/O on it push that button and the chair should come on Hope thjis helps
Posted on Apr 01, 2011
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
KA4iup, thanks for the answer but that is not what I need. On page 40 of Pride jet 3 ultra manual, the picture shows a quick disconnect cable. I need to know how to pull that apart without damaging...
The quick disconnect normally has a tab that when pushed will allow the connectors to come apart. You will have to look. The connectors normally are white nylon, but they could be any color. It should be there if the manual is correct for your chair.
Best I can do without seeing a picture or the chair itself.
Mar 03, 2015 | Pride Used Mobility Jet 3 Power Wheel...
Need a wiring diagram for a Jet mobility chair
Pride Mobility has the service manual on their web site. You can download it.
Aug 23, 2014 | Pride Used Mobility Jet 3 Power Wheel...
Pride JET 3 Ultra power wheelchair. Problem: Batteries drain very fast after recommended charge. Things I have done: Replaced both batteries- twice; Replace On-board charger. Both items brand new. ...
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jun 10, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Turn power on the light flashes & the joy stick does not work. what can be repaired?
The number of lights that are flashing can indicate what the problem is. Refer to your owner's manual for troubleshooting tips. You can also visit this website:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the type of controller that is on your scooter to determine what the lights mean. You will not be able to operate the power chair until the problem is cleared.
Oct 19, 2010 | Pride Used Mobility Jet 3 Power Wheel...
I need a replacement manual for my wheel chair by scooter model jet 3
Hi. Go to the pride australia web site. You might be able to download a manual. If not then just google pride jet 3 and see what you get. Good luck. Neil.
May 26, 2010 | Jet 3 Ultra Power Chair
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
42 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
