Question about Cell Phones
How do I get my bluetooth in the "pairing mode" so my blackberry can find it?
I have a black berry curve 8330
Posted on Aug 19, 2008
  • 117 Answers
What phone type and model do you have ?
Posted on Aug 05, 2008
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 | Cell Phones
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
Dec 02, 2008 | RIM BlackBerry 8800 Smartphone
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
