Question about Sakar 24280/24282 Digital Camera
No cam nothing dont even say it is hooked up! when i plug it in the red light on top lights up and XP see's something hooked up to usb and then nothing! can ton get pics nor will web start to work!
  • sbccj Aug 24, 2008
    is there anywhere i can get the instillation software for this? i have the driver from the web page but where can i get the photags express software other than in my purchase?
    Novelist:
    Scholar:
  • 149 Answers
It appears this same thing has been happening for other consumers of the same product. The manufacturer might of created a firm ware upgrade to this problem. First you can try to remove the batteries then put them back in after a minute to see if that solves the problem since it can reset your electronics.
Let us know how it works out or if you have found a solution since you have last posted on here.
Thanks for your time!
Posted on Oct 10, 2008
What is ritmo usb phone? A friend gave to me, said its for free international calls via internet. Looks like toy phone with usb cable, red lights flash when plugged into pc but nothing happens...?
You are hear to clarify your doubts. Ritmo USB is a Voip phone with Skype support. You can make and receive calls from Skype calls. Kindly plug into your computer's USB port inorder to make Skype calls from Ritmo USB phone.
Jul 13, 2015 | VIA Computers & Internet
Nothing happens when I plug this in. I've tried eSATA and USB, both with the power adapter. The blue light comes on but nothing else. The hard drive works in other enclosures so I know that isn't the...
Your assumptions are leading in the right direction.
  • The blue light would just be denoting power to the device the red light would denote drive activity. The limitation on this enclosure is that its white papers states a "Hard Drive Compatibility: 320GB HDD capacity", but I have seen people use a 500GB drive that seemed to work. If your using a drive larger then 320GB this may be an issue.
  • The enclosure HDD combo is Plug-N-Play via USB so this would mean drivers most likely are not the issue. I don't believe drivers are even packaged with the device which would mean they use protocol standard drivers from the OS.
  • Make sure that you are not hooking the USB up to a external USB hub (especially a bus-powered one) while trouble shooting as it may not provide enough power. Connect the drive up to system USB controller directly while trouble shooting.
  • I believe this device has the ability to hook up 2 USB cables at the same time for extra power (mainly while using the eSATA connection). Try hooking up the USB mini-B connector and the USB +5VDC connector and then hooking both up to the system on two different USB ports. This should then correct the possibility that your drive may not be getting enough power.
  • Lastly, the enclosure could have a faulty IC on the PCB. Exchanging it would provide the answer for that.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 02, 2011 | Eagle Tech ET-CS2XMESU2-BK 2.5" SATA to...
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
The controller won't sync with the PS3 system, even when I plug the USB connector into the USB port on the console. The red lights on top of the controller are supposed to flash when the controller is...
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the controller
READY.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Camera will not charge, should i be plugged in to the usb slot
please use youre usb and try again..that is the only way I charge mine
Oct 11, 2008 | Jazz DV-179 Digital Camera
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
I cant recharge my battery
i just bought the cam can you tell me how long it takes to charge the battery . i have had it on charge overnight and i stiil have a red light the cam works when it is pluggedn in but as soon as i unplug it nothing works. the reading on the camera is saying that the battery is full
Jul 25, 2008 | Jazz DV-179 Digital Camera
Doesn't work!! No red light!! Installed OK, but not camera!
USB DEVICES THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 14, 2007 | Veo Connect Webcam
PC-CAM 880 - remember Webcam mode
Uninstall all reference drivers to camera, reboot then install drivers again AFTER you hook the camera up to your computer.
Drivers can be found by clicking HERE.
Sep 12, 2005 | Creative Labs PC-Cam 880 Digital Camera
Sakar 24280/24282 Digital Camera Logo
Top Sakar Cameras Experts
Robert
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
