Question about Refrigerators
Drain tub stoped up - Refrigerators
Gaygayfshvjv;khkhhethanmeyereiiidhlhfdlfhpdfdpifhdklfhdlfkhdlfdhflkhdlfkhdlfkd
Posted on Mar 31, 2011
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
My washer started just find, then have way through the wash it stoped dispensing water and will not drain. Tried spin cycle only, and nothing. Tried unpluging, and still same problem Tried restarting...
all frontloaders have to start the drain pump before any cycle will start ... if there is something stuck in drain pump or hose between bottom of wash tub to pump washer will not spin... check filter pump assymbley and drain pump
Jan 24, 2011 | Frigidaire Washing Machines
Load not draining properly. have to run spin cycle multiple times.
Check drain hoses to be sure they are clear and not stoped up. You can probably tip the washer back to get to it underneath. If you have to, unhook them and run water through them. Check the water pump be sure it is turning. It may have something in it or be stripped and won't turn Take hose that goes from tub to water pump & be sure it is clear & don't have something in it like a sock to stop water flow. Check drain to sewer for water going out ok. Be sure drain hose is not too high unlikely. Best way is to remove cabinet so you can get to everything and see the water pump. Hope this helps.
Dec 05, 2010 | Kenmore 24032\24036 Top Load Washer
Code f 21 slow drain or stopped up . the drain lines are clear wh
Did you check to see if it is stoped up between the tub and the pump socks or somthing stops it up somtimes also check that the pump is turning and is not stoped up.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain out water . it will turn on shut offf and switch to diffrent options but it will not drain
Check the water pump or for somthing stoping up the pump or the drain lines.could be somthing like a sock in the water line from the tub to the pump . see if the motor is runing when it should be draining
Jul 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer stoped running and wont drain
Check you lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 8054980.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Apr 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine is not going through whole cycle It is not draining or spinning and clothes smell stale
Inspect drain hose for kinks or cloged up
Test the lid switch some models lid switch must be closed
Check water pump may be stoped up or not pumping
Check hose from tub to pump for blockage sometimes a sock or something will get in hose.
Check belts & pulleys if has any
Good luck
Apr 24, 2010 | Washing Machines
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have water under crispers not going to pan think drain tub e mite stoped up took frezer apart could not find it where is it
It's located below the coils inside the freezer at the very bottom. The water comes from the coils. Take a turkey baster filled with water and push the water down the drain. This will unclog the drain.
Oct 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
