Question about Toto Home
Flapper closes before toilet has completely flushed,
    Scholar:
  • 130 Answers
Sometimes those flappers get leaks in them and water seeps into the inside and doesnt allow the flapper to stay afloat long enough for the water to empty. Just replace the flapper with a universal replacement flapper. Very easy and cheap fix.
Posted on Mar 31, 2011
4 Suggested Answers
Malcg
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
gypsycat00
  • 224 Answers
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Posted on Jul 10, 2009
Wont complete flush
Could be low water level in the reservoir, otherwise the flapper may be shutting to quickly to allow enough water to properly flush. You could try holding the flapper open or watch it's operation as you flush the toilet to see if it's allowing enough water to drain into the toilet. It's pretty easy to replace the flapper on most toilets and cheap as well.
Jul 25, 2014 | Home
Bought a brand new Orion toilet and cannot get the flush regulated. Bought another new flapper and it will not always flush completely. If you adjust it too much it leaks at the flapper.
The flapper valve should be adjusted so it has only enough chain/rope to close plus a bit extra. If its too loose it may go too far back and take too long to close, if at all. If its too tight it will not close at all, and water keeps running. The tank water level should be set approximately 1/2" below the top of the overflow tube.
Jul 02, 2014 | Home
Toilet does not have good flush
The power of the flush has nothing to do with the fill valve. It has to do with the flapper. When the flapper is opened, the surge of water into the bowl is what causes the toilet to flush. If the flapper closes too quickly, it will take away from the powerful flush. Try to find the correct flapper for that type of toilet and stay away from the "universal" flappers.
Feb 06, 2014 | Home
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
The water keeps running. the yellow whatever you call it attached to the flapper get caught under the flapper
What is getting caught unger the flapper?
If your referring the chain that pulls the flapper up when you engage the level, that can be easy fixed by shortening/removing the links from the chain.
You can also remove the flapper and clean the hard water residue so it can create a proper seal.
Once your finished you can perform a test to ensure no more water is making it through when the flapper is sealed.
Flush the toilet, watch for the flapper to close. Once closed drop a couple drops of blue food coloring into the tank and /sigh.... Wait to see if you see it coming out into the toilet bowl. Check back in a half an hour. If no blue... Good job.
Hope this helps.
J.Sper
Mar 06, 2011 | American Standard Cadet 3 FloWise...
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Home Logo
339 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
