Question about Kodak C195 Digital Camera
My c195 keeps sayin lens obstructed and lens wont go down
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 31, 2011
Lens obstructed
Here are some troubleshooting steps that you can try that may correct your problem. If the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Above is a video summary of the steps:
Jun 26, 2013 | Kodak C195 Digital Camera
Water on inside of c195 lens
Hello Mike, This is best done by a qualified camera shop, too many things to go wrong when working with the lens unit, even a small scratch can be very costly as these lens are coated and if not handled correctly can be ruined.
Best Regards, Russell
Jan 10, 2013 | Kodak C195 Digital Camera
My kodak m583 tells me there is lens obstructed,and wont turn on
This video illustrates troubleshooting steps for a lens obstructed error:
Dec 13, 2012 | Kodak Easyshare M583 Digital 14mp Camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens obstructed errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 11, 2011 | Kodak C195 Digital Camera
Lens obstructed
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Aug 02, 2011 | Kodak C195 Digital Camera
Lens wont open completly
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Kodak C195 Digital Camera
I have a Kodak EasyShare C195. I was using it about an hour ago, I turned it off for about 10 minutes and then turned it back on and the lens went out but now it will not power down and it says lens...
Hi, It seems you need to reset your camera. You can do this by taking out the batteries for a couple hours. If this does not fix it, you have to take it to be repair. Where you bought it from.
Good luck.
Jun 07, 2011 | Kodak C195 Digital Camera
I dropped my camera now whenever i turn it on it say 'lense obstructed how do i fix it???
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Mar 18, 2011 | Kodak C195 Digital Camera
The lens on on my easyshare c195 doesnt retract. there appears to be a obstrution of the lens
There are two things we can try, get a can of compressed air use the attach straw and give two or three good blasts in the crevice "between camera body and lens housing" press power at the same time to try and get the lens to move, failing that! Take the palm of your hand and sharply hit around the lens housing pressing the power in order to get it to retract, this works better with small camera's and gets results most of the time. this second option does involve risk and could make things worse, but the reward of getting it going is even better. The main cause of lens sticking is dirt that builds up over a period of time.
Jan 30, 2011 | Kodak C195 Digital Camera
My kodak c195 keeps saying lens obstructed and the lens won't go down
There is a tiny motor that extends and retracts the lens, sometimes it will jam because part of the gear breaks causing it to malfunction, I would imagine the cost to repair will be high
Jan 10, 2011 | Kodak C195 Digital Camera
Kodak C195 Digital Camera Logo
2,073 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
