Question about Altec Lansing 221 Computer Speakers
When i plug the speakers into the computer, they have no sound. In the control panel, it says I have no audio device hoked up.
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
Computer detects speakers but no sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 26, 2011 | Durabrand 5.1 Surround Sound Computer...
I own a A/Lansing FX 6021, My right satelite speaker is not working( no sound, no buzzing at cable plug-in), are there any solution for this problem??
also
Oct 05, 2011 | Altec Lansing FX6021 Computer Speakers
No sound when plugged in
also
hope this helps
Aug 12, 2011 | HP (NN109AA) 2 Speakers
How do you fix the speakers
it will depend on what problems you you need to fix on the speakers be it of a physical nature speaker wiring or a software driver related or a dirty sound card or input plugs
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
hope this helps
Jul 09, 2011 | Logitech X-530 Computer Speakers
Do i connect the speakers to the monitor or the computer itself? afterwards, do i haveto go to control panel or anything in order to make it work?
does the monitor have speaker plug outlets??
the speakers plug/outlet is usually at the back of the computer or if its a laptop it could be a usb depending on your speakers once connected you might have to install your sound devices
(sound card)
also
hope this helps
Jun 29, 2011 | Acer 90.00012.30B Computer Speakers
Window audio
If you are having problems with you sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 18, 2011 | Logitech X-530 Computer Speakers
I took the plug out of the green outlet to move computer and when i put it back in i got no sound
also
hope this helps
Jun 17, 2011 | Dell AX210 2 Speakers
Wires plugged-in oke but no sound
also
hope this helps
Jun 08, 2011 | Logitech X-540 Computer Speakers
When we try to plug in the speaker plug it ill not make sound. We checked the Settings and the sound key was on but, when we tryed to play songs no sound came out of the speakers. How do we repair it?
also
hope this helps
Jun 05, 2011 | Logitech X-230 Computer Speakers
Using Philips SPA5200 speakers on a compaq laptop running vista. Control panel device manager says that the driver software is installed but device will not start code10. Control panel sound says no audio...
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 06, 2011 | Philips SPA5200 2 Speakers
Altec Lansing 221 Computer Speakers Logo
60 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
