Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have a Onan Microquiet 4000 in my Motorhome. It sat for a while and then I was unable to start it. I took off the carb and thoroughly cleaned it. The generator fired right up after that, it runs great under no load for about 20-30 seconds, then stmbles two or three times and resumes running great for another 20-30 seconds and starts the whole stumbling thing all over again. I also noticed that under the load of the AC unit it stumbles quite consistantly. Any help would be apreciated, Thanks
  • 718 Answers
Sounds like the float is out of adjustment, it's not keeping the bowl filled.If the float is not at correct height or the bowl was not placed back in the correct position it could show these symptoms , some bowls have a small indent on them and that recess should clear the float for proper movement of float. Or check to make sure that you have no water in fuel tank. Good Luck...
Posted on Apr 01, 2011
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Will not run without manuely chocking
Sounds like the unit has sat, and carb gum, Try draining the carb bowl and re-filling. There is a screw at the base of the bowl. Also make sure when cold choke is closed. And it opens fully after 3 minutes. Check battery voltage on choke coil.
Dec 17, 2013 | Onan 5500 Microquiet Generator
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan generator not running
recheck, reclean,and rebuild carb possible had moisture in fuel and carb --white smoke--but sounds like float and carb still gummed up
Feb 15, 2010 | Watts Onan Portable Generator - 4000 ,...
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
280 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
