Question about Electrolux Vacuums
Lux legacy vacuum runs fine and was recently serviced - yesterday the tone of the motor on the vac started a higher sounding pitch - is this a potential problem and is there anything i can do with it - thank you
  • 694 Answers
You don't mention whether it was the canister or upright model, but if it sounds differnet than what it usually does, then there is a potential problem. It could be anything from a full/clogged bag to a dirty filter to a clogged hose. You can check the hose by tyring to drop a coin through it.
If you didn't get it serviced at an authorized Aerus Electrolux shop, there could very well be other problems that were caused by an untrained service tech.
If it was recently serviced, and none of the above suggestions solve the problem, take it back to the shop that serviced it.
Also, keep in mind that these vacuums carry a 10 year warranty, but if serviced by a non-Aerus shop, the warranty is voided.
Posted on Apr 01, 2011
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Rainbow E series sounds "whiny" and loud while running
The whinning sound may be the bearings are bad. This will have to be taken care of or it will wear your motor brushes down very quickly. It is not generally caused by the filter, but by not be cleaned properly and may have been stored on its water basin.
Jan 20, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
