Question about Panasonic KX-T7633 Corded Phone
I'm trying to monitor the extensions for when they are in usage but can't figure out how to turn them on. For example, if extension 101 is talking to extension 102 the little red light will turn on letting me know about that usage for those two phones. I'm trying to have that feature on my other KX-T7633 but it won't do it. I purchased this phone used so it was already programmed like that. Any idea how to do it?
  • Panasonic Master
  • 2,460 Answers
Pick a set of buttons that you want to program, then press PROGRAM the button and dial 1+ the ext and STORE
The preceeding "1" tells the system that the next digits are extensions.
Carl
Posted on Apr 01, 2011
Testimonial: "This solved my problem! Thanks you!"
Changing the Time Displayed
Press intercom and dial 101, see which extension rings. That's 101
Mar 17, 2014 | Panasonic KXDT343 Phone
How do i transfer a call to another extension?
Unless your phone is connected to a TAW-848 or higher, your extensions are numbered 101-124 maximum, or 21-36. Try going to any phone but the main one and dialing either 101 or 0 and look at the display. You'll figure out your 3-digit extensions. Now just press TRANSFER and dial that 3-digit number. The outside call is put on hold when you press transfer, so there's no need to use the HOLD button.
As an alternative, you can press HOLD, putting the outside line on hold, and dial the 3-digit number into the intercom dial tone and announce the call for line number x. Or, dial the page code 330 and announce to all phones for the person to pick up line x.
Carl
Jun 16, 2011 | Panasonic KX-T7730 Corded Phone
PANASONIC KX-T7731 PHONE I HAVE MY EXTENSIONS PROGRAMMED BUT I NEED TO CHANGE THE NAMES FOR EACH EXTENSION AND I CANNOT FIGURE OUT HOW. THE PREVIOUS SECRETARY HAS BEEN GONE FOR 3 YEARS BUT HER NAME STILL...
I"d start by pressing the Caps Lock button on my keyboard to ask a question and use that key marked Shift to capitalize the first letter of a sentence and proper names.
Extension names are programmed in SYSTEM programming. Access to that is done from the phone connected to the first extension in your system, usually 101, with a system password. In a TA Series, it's program 604. In some others, it's program 004.
Carl
May 24, 2011 | Panasonic KX-T7731 Corded Phone
Hi, I have this particular phone as my work phone, The extension name is "craig" which comes up on the screen, This was the previous guy that was here before me. How do i change it to my name?
This is a program, you can do this from extension 101
1. go to extension 101
2.lacate program code 604
this is the program number for the extension name
any doubt please contact again
Hope this helpful
Apr 20, 2011 | Panasonic KX-T7633 Corded Phone
How do I use the intercom function on a KX-T7731 phone??
Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
Carl
Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
How can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
HI Expert Supporting, I have some problem
I just now realized that your TDA-100 is not correctly wired or set-up. You'll need to call the installation company that put it in. What you want: Is to have CO lines 3 and 4 to be accessed by extensions; 101, 102, 103... and CO line 2 to be accessed by extensions: 104, 105, 106, 107. CO line 1 needs to be dedicated to a particular extension; More than likely in your office. And then you would not have to dial 9..just pick-up and dial the number. Please stay in contact until we resolve this nasty trouble.
Master FixYa...saailer@att.net
Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
How do i program dates and times on the panasonic kx-t7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
Nov 12, 2009 | Panasonic KX-T7730 Corded Phone
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Nov 18, 2008 | NEC DTU 8-1 Corded Phone
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
137 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
