Question about DeLonghi Dehumidifiers
Dehumidifier model#DH40P filter neglected dust bypassed the filter, drain hose neglected, never drained seasonally as instructed in manual, alot of sludge buildup. after draining sludge into comtainer it appeared to have loose sludge remaining and blocking drainage. opened unit and cleaned parts visible. reconnected tubes. seems to sound normal again (quieter) but now blows only cool air instead of warm air and is no longer removing any moisture. container remains empty. compressor can be heard going on.
  • 115 Answers
Your compressor needs to be diagnosed, if freon is not getting pumped to the coil, this would be why.
Posted on Mar 31, 2011
Once you punch a hole in the receptacle, what type of screw cap would fit.
Most of the hose/drain connections i have seen on these have a std gardenhose fitting so you can use a std garden hose to direct the water over to drain, caps for garden hoses are easyly available from any garden supply store , but i do caution you on your thought process of hooking up a hose makes this a maintence free option, it does not as hose and filters still need constant cleaning , especally in high humidity seasons
Sep 09, 2014 | Whirlpool AD40DSL Dehumidifier
Pump not working
If you've checked power to the pump and it isn't working, it needs replacing, unless it's blocked with slimy deposits. Try a vacuum cleaner on the drain hose outlet
Apr 22, 2012 | DeLonghi DH40P Dehumidifier
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
Water bucket
If yours has a button/switch to turn on a pump, that will redirect the water to the drain. Sllee
Jun 28, 2008 | DeLonghi DH40P Dehumidifier
Drain hose not working
Hi, had the same problem. Not a glogging one. I have the model DDR503H. If it is insisting on filling the reservoir, it is because you haven't put the cap you removed from de back of the unit to plug the hose on the tank water exit. You have to first remove the tank and on the roof of this space, you will see the water tank exit where you can screw the cap removed from the back. You place back the tank into the unit and now the water won't have other choice then leak thru the hose. Also. to clean up the filter, I don't need to unscrew the top cover. I just remove the tank and on the roof of the space, there is a grey handle with arrows on it and I just pulled down, it comes out and you can then clean it up.
Hope this help,
Steeve
Jan 05, 2008 | Danby DDR401 Dehumidifier
Connecting drain hose to the Dehumidifier
If you go to this site you can download the owners manual. Follow the instructions and it should solve your problem.
http://136.166.4.200/contents/Dehumidifiers/DH30.htm
Sgt 48
Oct 20, 2007 | LG DH30 GoldStar Dehumidifier
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Drain hose attachment
Checkout this website...they have an owners manual you can download: http://us.lgservice.com/ A little hard to find, but it's there. In short, there is a small hole in the back of the dehumidifier between the cord handles. There will be a cap held in place over the hole by three small connectors. With some pliers, remove the hole cover. Take your hose connector and place it in the hole until it won't go any further (you can feel it hit the front of the water bucket). The instructions will show pressing the tab of your hose connector into the bottom of the hole to hold it in place. Don't know about yours, but mine is too long to do that. Connect a short length of garden hose to the threaded end of the connector and you've got it. Instructions say hose has to be flat leading straight from the dehumidifier to a drain, so don't place the draining end of the hose up in a sink or anything, use a floor drain. Hope this helps!
Jul 31, 2007 | Goldstar DH304 Dehumidifier
Dehumidifiers Logo
149 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
