Question about Whirlpool Refrigerators
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really dirty to begin with. please help - thank you
  • hammer2k Mar 31, 2011
    I actually met dial from 1 to 5
  • 57 Answers
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Posted on Mar 31, 2011
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
I cannot adjust the fridge/freezer temperature
Hi, there
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
We have a Sharp R&L Fridge/Freezer - it is freezing everything in the fridge compartment - please could you advise whether we should move the dial to Min or to Max to make it warmer inside to prevent...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 05, 2011 | Sharp Refrigerators
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer and fridge are getting warmer and warmer despite their settingsGE Profie PDS 20 MFS 2005
ONE OF THE MOST COMMON CAUSES FOR A SERVICE CALL IS EXACTLY WHAT YOU STATE, THE MAX SETTINGS ARE SET AND STILL ITS NOT GETTING COOLER, ESPECIALLY IN FRIDGE SECTION RIGHT?
IF YOU ARE MAKING ICE THATS DRY THE FREEZER IS OK,
THE PROBLEM 90% OF THE TIME IS THIS
AS THE FRIDGE SECTION IS RELIANT 100% UPON THE COLD AIR MIGRATING INTO THE FRIDGE COMPARTMENT VIA A LITTLE FLAPPER DOOR THAT OPENS OR CLOSES OR IN BETWEEN AS WELL , THUS ALLOWING MORE OR LESS AIR TO MIGRATE INTO THE REFRIGERATOR SIDE FROM THE FREEZER SIDE
THE STUPIDEST THING IS THE FRIDGE SAYS MAX COLD ON BOTH SETTINGS, ONE ACTUALLY CONTROLS THE COMPRESSOR AND DETERMINES HOW LONG THE COMPRESSOR WILL RUN IT USUALLY IS OFF AND 1-10 , THE ONE THAT TURNS OFF THE COMPRESSOR ISNT THE ONE THAT DETERMINES THE REFRIGERATORS TEMP! THE OTHER SETTING FOR COLDER FREEZER DOES!!!! TAKE THAT SETTING BACK OFF OF MAX FOR COLDER FREEZER AND THE LITTLE FLAPPER WILL OPEN ALL THE WAY , WHEN SET FOR MAX COLD THE FRIDGE SIDE STARVES!, ANY SETTING 1-10 SHOULD STILL KEEP THE FREEZER FREEZING AND MAKING ICE IS THE KEY! IF IT CAN THEN ITS NOT A REFRIGERATION PROBLEM , IT IS A CIRCULATION ISSUE
Aug 23, 2009 | GE Refrigerators
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
263 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
