Question about Nintendo Wii Console
No power light on after storm. We replaced the battery and waited 1/2 hour before plugging it back in.
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
Sanyo DP19649 went black, no sound. Socket live for other appliances. Changed remote batteries. No storms or power failures.
There is no reset button
Unplug tv for 1 hour then plug back in
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 19, 2012 | Televison & Video
I got a Blackberry Storm 9350 its been working perfectly since I got it however yesterday the phone just died and does not want to switch on again. I took the battery out and put it back and the phone and...
v r epair specially black berry and iphone in mumbai if required u can ctc me we can get it checked as far as i understand it has got a shorting somewhere.
Mar 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
My blackberry bold 9700 wont turn on or charge, and the orange light wont come on....
First u plug in your mobile phone with charger and wait for atleast 1 hour your battery is fully discharge
Nov 02, 2010 | RIM BlackBerry Storm 9530 Smartphone
NOTHING SHOWS ON THE SCREEN OF BLACKBERRY STORM, HE CANNOT SEE THE KEYS TO FIND THE MASTER RESET, IF THERE IS ONE.
If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre.
Nov 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
My bb storm screen doesnt come on the phone is on but the screen doesnt come on
Not to worry , If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre
Nov 19, 2009 | RIM BlackBerry Storm 9530 Smartphone
MX6448 won't boot; black screen.
It seems that you don't remove the battery when you use the Notebook. This practice shortens the life of the battery because, when you use the a/c adapter and the battery, your battery is alternately charging and discharging all the time. The cells in the battery eventually die.
From what you describe, it sounds like the power strip inside the Notebook (where you plug in the adapter cord) has been damaged and needs to be replaced.
Your computer is not a total loss. Just have that power strip and the battery replaced and your Notebook should be up and running again.
And, in the future, if you just remove the battery when your kid uses the computer, or if you are going to be using it for over 1 hour. Save the battery to use when you need the mobility.
Oct 10, 2009 | Gateway MX6448 Notebook
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Jun 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
Nintendo Wii Console Logo
94 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
