I have a splendide 2100xcp. when I wash a load and the drum spins it makes a knocking noise. once knock for one turn of the drum. After my clothes were done, I stick my hand in there and turned the drum with the machine off and the noise was still there. Could the belt have slipped? or could it be the motor? Can I align the drum? What do you think it would be? The unit is on level ground. the unit is not even a year old and I'm already having problems:( I haven't taken it apart yet but am going to. I just downloaded the tech/training guide. Thanks for any advice.
SOURCE: Drum noise
Good day.
Maybe there are coins left in the pockets that stucked within the drum during drain process. You can also check the bearing holder of your washing machine for this is also one of the reasons why noises occur during oepration
chris
Posted on Mar 11, 2008
mikedurland
  • 481 Answers
SOURCE: washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Posted on Jul 14, 2008
  • 10 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Posted on Jun 01, 2009
  • 68 Answers
SOURCE: loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Posted on Nov 14, 2009
Testimonial: "Thank you for your reply. That was the problem! Thanks again."
  • 1937 Answers
SOURCE: I have a Kenmore 110-24642300 Top Loader washing
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
And the following for how to release the console, cabinet and pump, motor, transmission and tub.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=38167c09664cecf006774770a74cf9bc
DON'T BE ALARMED, THE ABOVE ARE REFERENCES AT THIS POINT. YOU CAN FIX IT. (THESE ARE RELATIVELY EASY TO FIX IF YOU TAKE YOUR TIME.)
The first thing to check is how well the tub is attached to the spin tube. Over time, the nut that holds the tub on may have worked loose. The description for how to pull the tub should help.
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
If the tub is firmly attached to the drive tube, the next thing to check is the drive tube itself to make sure that it's not broken. Pull it (following the illustrated instructions and the Service Manual) and check it. Also check the pads / springs for the brake.
NOW FOR THE FUN PART.
If the tub is fine and the drive tube is fine, the problem could be in the gearcase itself. (It's a messy but not difficult job)
There are two plastic cams within the gearcase that lift the agitator shaft out of the way when the washer goes into spin mode. If the cams are worn (they don't have to be broken) they may not lift the shaft high enough (about 1/16") out of the way.
Also see the following for how the transmission works and the whirlpool parts list for the commercial washers (although the consumer models use the same gearcase.)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of oil in the transmission) but very inexpensive.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, check the clutch bands and springs before going further. If they are worn, sears and Whirlpool have replacement spring / band kits. If they are fine, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft.
Remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Apr 26, 2010
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
2001 Gibson Washing Machine - Front Loader
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 29, 2008 | LG WD-12126RD Front Load Washer / Dryer
Spin cycle make noise
from what you wrote the signs are that the bearings have gone
Dec 17, 2013 | Indesit W 123 Front Load Washer
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Knocking in trany during agitate/wash cycle
Probably a bad tranny or bad bearings on the tub.
Mar 12, 2010 | Washing Machines
Knocking in washer
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Sep 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
