Question about Samsung SMH7178STD Microwave Oven
Samsung MW SMH7178STD Not Heating
Wilbur,
Could you elaborate on the "no heat" issue? My Samsung SMH7178STD is not heating, everything else seems to be working as normal, including keyboard and fan. Does this sound like the magnetron? Can I replace this myself? I'm pretty handy, even having disassembled a microwave before (found the source of the problem to be a tree frog that got onto the circuit board and fried himself!).
Thanks,
Gordy
  • 2 more comments
  • MHBest Aug 25, 2008
    Wilbur,
    Thanks,
    Gordy
    I'm having the exact same problem with the same model. Everything works but the heat. Help!
    Mike Best
    gottabbest@yahoo.com
  • wamerman Sep 19, 2008
    I have this same problem. Everything operates like normal, except tonight it just stopped heating anything. I've changed power levels, tried defrost, etc, but nothing gets heat.
  • Anonymous Sep 30, 2008
    not heating
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
  • Samsung Master
  • 9,098 Answers
I would think it may be a failure of the cook relay on the board, since the noise is quieter.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Sorry i can't help more. This will need troubleshooting.
Posted on Aug 28, 2008
I have a samsung smh7177ste/be microwave that will not heat. Every thing seems to be working as normal
The problem is one of three things, the magnetron "common issue" or the high voltage capacitor and diode can be a factor, the above mentioned work together to heat food. Depending on the nature of the repair, parts and labor can run as high as a new microwave oven.
Mar 02, 2011 | Samsung SMH7178STD Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Emerson MW 8119 runs everything but does not cook?
your magnetron is the heating source and that is why it is not heating. may not cost to repair mag is about 100.00 for the part.
Feb 24, 2010 | Microwave Ovens
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
No heat!
you have to replace the heating element for that old microwave. its already been 3 years. sometimes this do happens because of the use and this is the solution.
Apr 01, 2008 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
252 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
