Question about Car Audio & Video
I need to know the wiring diagarm so i can wire it to my 1991 plymoth sundance can you help
  • 8,215 Answers
Hi, below are the colors of the wires in your car. Is this what you needed?
1991 Plymouth Sundance Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Back Strap
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: Orange/White
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersi need to know the - ir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Green/Yellow
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Purple/Yellow
Rear Speakers Size: 5? x 7? Speakers
Rear Speakers Location: Side Shelves
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Brown/Yellow
Right Rear Speaker Wire (+): Blue/Red
Right Rear Speaker Wire (-): Blue/White
Posted on Mar 31, 2011
  • 1 more comment
  • wayne anderson Mar 31, 2011
    no this is not what i needed i need the wiring diagarm for a sparkomatic am/fm cassette radio #sr430 to put it in my 1991plymoth sundance thank you very much
  • Jeff Turcotte
    Jeff Turcotte Mar 31, 2011
    That one is really old. I found a post here where a guy has a sparkomatic wired up and working:
    http://www.audiovisualtalk.com/showthrea...
    see if your wires sync up with what he has--only 6 wires on his head unit.
  • wayne anderson Apr 01, 2011
    i am thankful for your help i saw that post but that dosn't help me with the wiring diagarm thanks
91 sudance wont start, it wants to turn over though.
did you try the pick up coil or hall effect,its under the dist cap with a wire coming out to a plug.
Feb 28, 2013 | 1991 Plymouth Sundance
I have a 1991 plymoth sundance and the turn signal blinkers dont work but the wipers do I have checked the fuse what else could it be
Hi, there is a flasher relay behind the glove box. Find this, pull it straight out of the socket and replace it. You can get one at any auto parts store.
Mar 31, 2011 | 1991 Plymouth Sundance
I have a 1991 plymoth sundance putting a after market radio in it i put the speakers in hook them up turn the volume all the way up and the music sounds real low what is the problem please
Sounds to me like the speaker wires may be reversed but then again I'm not perfect, just don't tell my wife that. Anyhow here is the wiring info for your vehicle just to double check. I hope this helps you and good luck.
1987-93 Plymouth Sundance Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination n/a Dimmer Orange/White Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 5" x 7" Side Shelves Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
Mar 28, 2011 | 1991 Plymouth Sundance
Hello can you tell me how long and how hard it is to enstall a brake booster in a plymoth sundance 1994
If there is proper add on kit available , it becomes easy to fix it provided that it matches with the existing unit.
It can be done in a day, to add on the fittings , giving the vacuum feed and bleeding off.
But all the wheel cylinders must be checked when the efficiency is improved.
Sep 27, 2010 | 1991 Plymouth Sundance
Where is the computer located on a 91 plymouth sundance. I think this is causing the voltage to jump to almost 18V and the grounds have been checked and the altenator replace and still having problems so I...
need to know if 2.2 or 2.5 if 2.5 need to know if turbo, i would get the alternator checked because the voltage regulator is in alternator not computer, just cause new alternator doesn't mean good, have it checked out
Feb 17, 2010 | 1991 Plymouth Sundance
How to fix emergency brake on 1991 plymouth sundance. when i push down all the way the brake light in the dash comes on but the car doesnt stop
There is a wire split under the car on driver side,but follow the wire and you should run into the prob.
Oct 27, 2009 | 1991 Plymouth Sundance
What is that thick wire thats connected with a
Its a security wire to keep the radio from being easily stolen!!
Sep 19, 2009 | 1991 Plymouth Sundance
Digram on replacing heater core
i have a manual with step by step instructions,no diagram but helpful.
if you still need it i can scan it and email it to you
Oct 16, 2008 | 1992 Plymouth Sundance
Car Audio & Video Logo
236 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
