Hi I have a prosound vango swing which has no power getting to the light. The motors both work when switched on but there is no power at the connection of the lamp on the circuit board. Can you help please. Many thanks In anticipation Mr M Brooks
SOURCE: Power Surge damage. Suggestions on which part to replace.
I would start looking at the power supply, it's usually a separate board where the a/c line plugs into. In many cases i have seen that the problem you described is from a damaged power supply, sounds like something is shorting causing the power supply to continuously come on and off. I would first check the capictors to see if any of them have blown, usually cylinder looking and sometimes you'll see an X or a K at the top of the cylinder, if it's blown then the top will be bulging out instead of being flat. If all those look good then there is probably a short somewhere else like in one of the transistors, if so you'd be best to just find another power supply board to replace.
Posted on Nov 09, 2007
worldvet
  • 859 Answers
You probably have a sacrificial diode that blew out to save the rest of the monitor from further damage. The manufacturer should replace it with a refurbished one at little and sometimes no charge (comparatively speaking).
Posted on May 10, 2008
SOURCE: jvc gz-mg330ek--will not power up--will not switch on
hi.
thank you for your email.
i have since sold the camcorder on--no more problems with it.
best regards
mr.j.b mc dermott---brunhouse.
Posted on May 29, 2008
  • 659 Answers
SOURCE: mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Posted on Mar 21, 2009
john224
  • 1378 Answers
SOURCE: circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Posted on Jun 13, 2009
Se280lc-2 Samsung excavator hydraulic motor and swing motor are not working
main pump is faulty, swing switch faulty, swing brake stuck or activated, swing motor bad, filter clogged.
Dec 16, 2013 | Cars & Trucks
ProSound 1600 Professional Power Amplifire, No Manuals, No Service, No Manufakturwebsite? Who can help???
Try on google, To do a search.There are sites where you can download manauls for no charge, I found the owners manaul for my adcom Power Amp that way. End it is over 15 years old.
Oct 21, 2012 | Audio Players & Recorders
Prosound 1000 amp protect light
If the amp has an overload protection to it, which is sounds like it does, there should be a reset for the amp or a method of resetting the amp to working condition. Go to the manufacturers website and look for that or send them an email. They will be able to direct you.
Sep 28, 2012 | Technical Pro Integrated Amplifier 1000...
The Bright stars swing is not working anymore. We put in 4 new D batteries but the swing does not have the same power? What can we do?
You'll probably need to replace the motor in the swing. Most of these types of swings work off a motor with a plastic gear attached, and the inside of the gear gets worn down over time. The motor still gets power and still turns the gear, but the gear doesn't have the grip that it used to so the swing doesn't move as much (especially with a baby in it).
Feb 04, 2011 | Kids II Bright Starts Travel Swing
Prosound MMX 410 DJ mixer. Cueing a track
Select the channel you wish to listen to on the headphone select switch and turn the volume up.
Jan 08, 2010 | ProSound Electronics - Others
Swing is not working at all
are the linkages to the swing motor broken?
is the swing motor working?, if not then it is either the swing motor switch or the motor its self
May 02, 2009 | Whirlpool ACQ108XL Air Conditioner
Baby swing......graco doesn't swing
I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend http://www.toysrus.com/product/index.jsp?productId=3420749&camp=PPC%3A204318389. its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
Mar 29, 2009 | Baby Gear
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Prosound Power AMP, no sound available
hi jacko, i had the same problem with my prosound 1000.
changed all the fuses etc with no luck.
then as a last resort, i tried wiggling and lightly tapping the internal wires on the main board then all of a sudden there was sound!
i know next to nothing about electronics but i am thinking that i may have reset some kind of power protection cut off that may have been sticking, but what do i know?.
Please, like everything else electrical, if you do try this, make sure power is off first.
hope this helps, its worth a try.
paul
Jan 22, 2008 | Audio Players & Recorders
115 people viewed this question
 Grubhead
Grubhead
