Eberspacher slow to start then lots of white smoke for a few mins before it starts to work properly
TampaNative
  • 778 Answers
SOURCE: Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Posted on Sep 05, 2008
SOURCE: white exhaust smoke
Quick Answer buddy Warranty!!!!!
Posted on Sep 11, 2008
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
  • 7 Answers
SOURCE: lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Posted on Jun 09, 2009
  • 257 Answers
SOURCE: 2000 TDI - Lots of white smoke at cold start.
Sounds like your injection pump timing is off, an injector is leaking or a bad seal on your IP.
VW dealers have a horrible reputation when it comes to TDI's. Check out the posts over at www.tdiclub.com Those guys are very knowledgeable - and the first thing they'll tell you is don't take it to a dealer.
You can probably find someone in your area that has a copy of Vag-Com (scantool software that vw uses) software that could look at your timing. It definitely sounds like your dealer was throwing parts at your car because they didn't know what your problem is. If I were you, I'd copy and paste your post from here over at www.tdiclub.com
Posted on Jul 21, 2009
3.0 litre V6 turbo diesel Mercedes. 115,000 miles. When it is left on tickover for 10 to 15 mins starts to smoke white/grey smoke from exhausts. After a few minutes of normal driving the smoke stops.
Possible cause is several drops of oil are leaking past the valve guide seals when the vehicle just sits. When it is started the oil begins to burn off in the cylinders and after awhile the smoke disappears. I have always recommended cha going the oil to a synthetic and adding an oil additive called Restore. It comes in a cylindrical can in 4, 6 or 8 cylinder size. Put 1 can in with the new oil. Drive the vehicle on the highway for 45 - 60 minutes. I recommend putting on a few hundred Mrs. The additive restores the valve seals preventing the oil from dripping into the cylinders. Have used it on my customers vehicles for 20 years. Saved them a lot of money from replacing the seals.
Jun 16, 2017 | Cars & Trucks
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
New Toyota Etios, VD,KM 1100, observed thick white smoke from exaust pipe for @ 1 Min, while running engine on ideal.
the white smoke occurrence is due to unique Vehicle usageconditions like slow speed & Short trips drivingthe catalytic convertor is not able reach its optimum reactiontemperature. As a result, the Hydrocarbon accumulates in the Catalytic Converter.After sometime, once the saturation limit is attained, the accumulated Hydrocarbon
starts burning inside the Catalytic Converter. During this Chemical Reaction,Momentarily the white smoke is seen in the exhaust and is normal
Jan 20, 2013 | Cars & Trucks
It blows white smoke out the tail pipe when i start it
You must have a leaking engine cylinder head gasket. Have a local shop confirm this for you as it is a very expensive repair.
Jul 17, 2012 | 2003 Chevrolet Cavalier
Hi i have just fitted a eberspacher d4 to my boat it starts up well but after 20 mins it shuts down but will fire up again after a few hours ?
it could be that the fuel filter is cloged up or pump but theres defo a fuel problem is there any kinks in the fuel pipe i had a car that was doing same thing
Feb 19, 2012 | Heating & Cooling
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
Hi,eberspacher d4 airtronic prob,the power supply from battery was disconected whilst it was still running,so it didn't shut down properley,now it goes through the starting sequence x 2 but fails to start...
We have an Avondale Seascape Motorhome 54plate which has Eberspacher heating - (D4) - It strikes up and heats for about 1 minute - then cuts out and does not go again - have been to a garage who tried a new timer - without success - anyone out there with any idea to a solution- also estimate as to what it would cost
Feb 09, 2010 | Heating & Cooling
VW Golf 1994 died as if the key was turned off; will not restart.
Could be a head gasket leak as white smoke is a sign of water. I would suggest having it checked. It doesnt take alot to cause white smoke.
Jul 28, 2009 | 2000 Volkswagen Golf
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
