Have 4 yr. old lennox r410a split system heat pump that reversing valve is sticking halfway. can turn unit off and back on and system operates normally for a few cycles then sticks halfway again until you turn unit off and on again. we have already replaced reversing valave and problem still exists. also replaced solnoid coil at time of r.v. replacement. have checked and ensured 24 volts at coil.
  • 182 Answers
Double check the txv
Posted on Aug 05, 2008
2 yr old Lennox heat pump; is blower supposed to come on randomly whether or not heating or cooling?
check your fan setting. possibly have ON/ AUTO/ CIRC. Circulate means the fan will run periodically.
Oct 18, 2017 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Carrier heat pump
Expansion valve is sticking shut
Jun 13, 2013 | Carrier 5 Ton Complete Split System Heat...
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
May 06, 2017 | Goodman Heating & Cooling
I have a Lennox CH23.51 series coil unit using R22 freon installed one year ago. Compressor is 9 years old. Down the road when replacing compressor (R410A ), will CH23.51 unit be compatible after changing...
This evaporator core is R-22 / R-410A compatible. The Thermostatic Expansion Valve (TXV) is for R-22. If retrofitting to R-410A, a new TXV metering device would be required, but the evap. core itself could be re-used (as long as you stick with the same Tonnage you have now). If upgrading to a higher tonnage system (like going from 4-Ton to 5-Ton), then you would need a totally new evaporator core.
Jun 08, 2010 | Heating & Cooling
Honeywell Wireless System THM5320R Wireless system and thermostat startup ok. The issue I am having is that; when the thermostat is in cooling mode and the unit starts the reversing valve is in the wrong...
how old is the existing system? i do ac in florida and usually if its not the wiring, an old systems rev. valve may stick. a firm tap on the valve may solve your problem.
Oct 28, 2009 | Heating & Cooling
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
