Inside unit sweats during daytime hours - Heating & Cooling
  • 182 Answers
Dont shut it off at night.....humidity is too high indoors.
Posted on Aug 05, 2008
Why Motion Light Do Not Work?
Your English is too broken to understand what you mean.
Aug 13, 2014 | Home Security
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
No night pictures
You cant see infrared flash, but it is not working. The only way to check this is with special equipment. If the unit is new, send it back.
Nov 18, 2013 | Moultrie Game Spy M80XT
Installed Symmons Temptrol II Shower Faucet and do not have flow. Rebuilt it twice. Could accidently overheating the valve during copper sweat cause damage to the Hot and Cold Seat cause a flow issue...
unless u sweat the valve body while the cartridge or ball **** (not sure whats in that model) was in it, there shouldn't be a problem.the seats are made of brass or steel and will not be affected by the heat of sweating copper. there may be a spring w/a little rubber boot over it that is actually in the seat which could be damaged like this but i have never seen a unit come out of the box like this. i mean you have to put them in there yourself. it is standard however for a cartridge to come inside the valve body so hopefully you took it out before you started sweating otherwise you will definitely have to replace the cartridge:( hope this helps but if you need anything else just text me here:)
Jul 27, 2011 | NRS Symmons Allura Pressure balancing...
Tank sweats profusly
Sweating tank can cause moisture problems inside bathroom.
Sweating is caused when incoming water temperature is hotter or colder than air temperature inside bathroom.
You can verify this by not flushing tank for several hours and notice that sweating stops once water inside tank warms or cools to same temperature inside bathroom.
Problem can also be cause when there is not enough ventilation inside bathroom and water on tank does not evaporate.
To solve problem:
1) Increase bathroom ventilation and add dehumidifier or fan so condensation drys.
2) Insulate interior of tank. Empty water and let tank dry. Tape off moveable parts. Use can of spray foam and insulate inside of tank. Let foam dry and cut away excess foam.
3) Add tempering tank or staging tank inside room to pre-heat/cool water before it enters tank
Mar 22, 2011 | Eljer & Titan Elongated Toilet Bowl
I have a ten year old carrier heat pump unit. I recently replaced the indoor tstat. the outside contact and the transformer. Had a tech put freon in the unit also. I have to problems one is the airflow is...
Two things are the most likely culprit. First check ytour inside coil with the unit running for 10 minutes or more and see if the coil is sweating there should be water running off of it. Also after one hour is there ice forming on it. These problems are lack of air flow which is caused by restricted air flow caused by a dirty filter dirty coil (which you have already taken care of) or your blower motor may not be kicking into high speed. Your motor will start and then after it gets to a certain speed it switches to a high speed. After running only 15 minutes if your blower motor is hot to the touch. Be careful some will cook an egg. If it is hot not just warm it is bad and needs to be replaced. Also if the fan is not running properly you can not get reliable readings with your gauges when adding freon. So if this is the problem then you may have to have the units freon cked again. If the line is not sweating at the outside unit where it goes into the unit the freon pressure is not right. The larger copper line will be cold and sweating the small line will be hot to the touch when the system is balanced and running properly. I hope this helps
Aug 23, 2010 | Heating & Cooling
What is the a/c charging pressure on roof top r/v units?
The easiest way to charge a unit is to add freon to the low side until the line sweats and the coil is sweating top to bottom. The pressure depends on the wet bulb temp on the low side line the ambient temp outside and the intake temp inside the
RV. A good unit will start to sweat between 50 to 78 pounds on the low side. good luck
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
Error code 8 appeared and now cannot get basket
The machine did not complete its cycle, either while finishing a brewing cycle or a cleaning cycle. This is caused because the motor is not strong enough and overheated. I think it is a design problem, but there is a "work-around" solution.
First, to put basket back, look inside opening. You will see a flap at the back of the opening. This flap is down and is what is preventing insertion of basket. Take only the grounds basket. Tilt the grounds basket and insert it so the back end of basket goes under the flap. Then level out the basket. Note the flap is now inside the back end of the grounds basket. Holding the basket up and level, re-insert the drip tray and the basket holder underneath the basket. These should now slip into place.
The "work-around" solution is to let the motor cool down. Unplug the machine for at least 30 minutes, then turn unit back on, and the cycle should complete because the motor is now cool.
I notice this error 8 happens mainly when the voltage from the Hydro Utility is low. This happens during peak electricity usage hours. So, to clean your machine, do it on the week-end during the daytime either mid-morning or mid-afternoon.
Good luck
Sep 27, 2009 | Jura Capresso Coffee Makers & Espresso...
Hi, Sounds like its low on refrigerant. Could also be restricted air flow inside. Turn the AC off and the inside fan on for about 3-4 hours to thaw out the evaporator. Replace the inside air filter. If you can see the side of the evaporator that the air goes into, check to see if it has a blanket of fuzz on it. If so, It can be cleaned with a credit card while its wet by scraping along with the fins. Turn the AC back on and let it run for about 20 minutes. The large line outside should sweat all the way to the compressor but the compressor should stay mostly dry. There may not be anything wrong with you unit. When it is cooler at night they will sometimes freeze if the thermostat is turned down too low during the night and the air restriction will not let it thaw during the day. Hope this helps. kstfas
Sep 19, 2007 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
