Question about Brother HL-5240 Laser Printer
Replaced fuser brither hl-5240 but still prints slowly how do I reset
Soulvisitor
  • 1113 Answers
SOURCE: Brother 5240 laser printer changed toner still wont work.
When a brand new toner is inserted it has a switch that is activated when new cart is installed.
Machine has two toner light errors blinking is toner low, full on is toner out all stop,
 I guess yours has not reconised new cart, was it new out of a sealed box?
If so then it failed to reset upon install
You can pull apart reset lever on left front of cartridge and reset to original position if you want to get just a little tecnical
One sctew carefull gears fall off ,white lever needs to be fully to rear of slot to emulate new cart status..
If brand new cart return to supplier as faulty.
If you just refilled it, go buy a real one to prolong life of your product
Posted on Oct 20, 2007
  • 12 Answers
SOURCE: Brother HL 5240 won't print
Right Click on My Computer, and select Manage. Look at Device Manager and look for any yellow exclamation marks. It may not be installed.
Posted on Apr 25, 2008
nyilasrobert
  • 627 Answers
SOURCE: BROTHER HL-5170 FUSER COUNT RESET
To reset the drum you have to hold down the go button untill all the lights light up and flash.
Posted on Aug 05, 2009
komguy
  • 2306 Answers
SOURCE: How do you replace the drum properly on a Brother
Out with the old and in with the new, you remove the toner and drum together, remove the toner from the old drum by pressing the blue lever on the side, install the toner in the new drum, and re install in the printer. With the front door open press the go button til all lights flash and then close the door, the new drum is reset.
Posted on Nov 20, 2009
SOURCE: My printer brother HL 5240 making knoking sound
i had that for awhile until i realized i didn't have the tray that held the paper fully extended. once i figured that out it has not been knocking. now i have toner light on, its always something
pull the tray out and make sure in the back of the tray it is full extended, the paper will lay nice and flat.
hope that works for you like it did for me
Posted on Apr 18, 2010
Fuser reset brother hl5240
how to reset fuzar for brother hl 5240 lazar printar
Mar 23, 2012 | Brother Office Equipment & Supplies
Paper jams just before it comes out. Complete image has printed but the page doesn't "come out", gets jammed. If doing 2 page print usually only half of the second page will print as it backs up behind 1st...
This sounds like a classic fuser failure. Take the printer to a qualified repair facility and they can replace the fuser and check all of the fuser and exit drives for proper operation.
Jun 16, 2010 | Brother HL-5240 Laser Printer
Prints thick black lines
Hello, Andrea.
Sounds like either your printer needs a new fuser assembly (If the teflon roller gets scratched or starts to disintegrate you will get lines or black marks on the page) or you need a replacement toner.
Hope this helps.
Sep 14, 2009 | Brother HL-5240 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
HL-5240 paper stops before fuser
Your problem is actually the fusing assembly. It has a bad lower roller. It can be viewed by opening the rear door and then the inner rear door. Unfortunately it requires replacing the full fuser and it's expensive. Approx. $170.00.
I know the news is not good but hope it helps you.
Call Brother if it's still under warranty! If not, precisionroller.com stocks them at approximately $170.00
Mar 26, 2009 | Brother HL-5240 Laser Printer
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
HL-5240
Unfortunately your problem is with the fusing assembly. This is not a cheap part at all. It's available at www.precisionroller.com for around $170.00. The problem is the lower silicon roller in the fuser. If you open the back door and then the back inner door, you can view the fuser. The part your looking at is the orange roller. It will either be wrinkled, ballooned, or separating the outer clear sleeve from the inner core. The last one is a little harder to see without a flashlight or similar. If you look close, you'll see the clear silicon oil inside between the outter sleeve and orange core. If the printer is still under warranty, call Brother for a replacement fuser. I know the news is not good but, hope that helps you.
Feb 23, 2009 | Brother HL-5240 Laser Printer
HL-5240 Appears to need new toner but that didn't fix it.
If the marks on the page appear to repeat three or four times down the page regardless of what is printed, it could be the drum unit ( the unit the cartridge fits into) You can test this by taking the cartridge out of the drum and looking at the cylinder in the drum unit. If has light coloured bands, or looks very black, then it is at or past its life cycle ca20-25k pages. If it has clots of toner stuck to it but is otherwise ok, you could carefully clean it with alcohol and a cotton ball to remove the toner clots. Steady and patient is more rewarding than trying to grind the stuff off. If the drum looks reasonably clean, open the flap at the back of the printer and look closely at the fuser. If there are clots of toner stuck to the orange pressure roller or to the grey/tan fuser roller, then the fuser will need to be taken out and cleaned also with alcohol, cotton ball and much patience.
Feb 13, 2018 | Brother HL-5240 Laser Printer
Brother Hl-5240 Laser Printer leaves black lines down page when printing
Replace drum if you've tried cleaning corona wires, if no improvement fuser nearing it's life end?
Aug 25, 2008 | Office Equipment & Supplies
Hl5240 laser
Fuser unit will need to be replaced, very common workshop job on these machines.
Oct 25, 2007 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
