Question about Acer Computers & Internet
My Acer Aspire suddenly won't let me work on it EXCEPT with a mouse! Can't use the touch pad -- either the cursor is locked up OR it isn't even visable when I try to use the touch pad. HELP!
    President:
  • 1,335 Answers
Check the switch on the touchpad (ususally a button on the touchpad) to make sure the pad is switched to ON.
If the switch is ON, check the status of the touchpad by going to START>ControlPanel>System>DeviceManager>Mice and other pointing devices
Click on the touchpad and make sure the Device status is "the device is working properly"
If everything checks out, you may have to reload the driver.
Let me know what you find out and we can go from there. Thanks.
Posted on Mar 31, 2011
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Apr 10, 2013 | Acer Aspire Computers & Internet
I have an acer laptop and the cursor jumps all over when im typing and randomly selects sections im not touching the mouse pad at all
80 % IS MOUS DRIVER , 10% MOUSE PAD ,dis able the , the touch pad from front of the top case by switch , and connect the external mouse and check the system.
Jan 09, 2013 | Acer Aspire 7110-2069 Notebook
Acer aspire 1642 frozen mouse
Connect an external USB mouse to get at least the cursor to work, then download the latest touch pad drivers from Acer's site
Check that you have not disabled the mouse pad (FN and F7?)
If that fails, you may need to dismantle the laptop and check the small ribbon cable that connects the touch pad to the motherboard has not come adrift.
After that it looks like physical failure of the trackpad / touch pad assembly
Jul 18, 2011 | Acer Aspire 1642ZWLMi Notebook
The cursor touchpad is not working on my acer laptop it works ok with external mouse
Tap the touch-pad toggle key once and check if the touch-pad disable indicator is off.
Then try using the touch-pad.
Oct 28, 2010 | Acer Aspire AS57405513 Laptop with 156"...
What is the internal touch pad?
internal touch pad is the touch pad where you put your finger to roll over your cursor instead of using an external mouse. External touch pad is also called external mouse.
Oct 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
FROZEN CURSOR
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
Aug 28, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
The cursor will not move after I start system, what can I do?
check your key bord is working if it is working then you need touch pad drivers if you have other usb mouse you can check it with usb port of laptop if its work then you can solve this issue with touchpad drivers installation.
you can download your drivers from this link just select your odel from here.
http://us.acer.com/acer-v2/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Jul 27, 2009 | Acer Aspire 5720-6661 Notebook PC
My Acer Aspire 5720-4126's touch pad suddenly doesnt work. Even the usb mouse doesnt work.
check driver in device manager update
in control panel check the settings for mouse.
clean the mouse pad
let me know
Feb 22, 2009 | Acer Aspire 5720 Notebook
How do you fix a frozen mouse for a acer aspire 5315-2077 laptop?
Fn F7 probably got pressed (turns on and off the trackpad. probably the dumbest thing to have a hotkey for)
Jan 16, 2009 | Acer Aspire 5630 Notebook
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
