Question about Whirlpool Washing Machines
The door is locked and a flashing F 21 message
  • 5,370 Answers
The F21 indicates a long drain problem.There is a drain problem.If you haven't already the first thing to do is to remove and clean the pump filter. See the image below for how to do this. Remember to unplug the washer first.You will want to have a shallow pan or a couple of heavy towels to catch the small amount of water that will come up when you remove the filter.Hopefully the filter can be cleaned out and you'll be back in business. If the filter is clear and the pump is noisy or pumping very poorly the replacing the pump would most likely correct this problem.
This should help.Thanks.Helpmech.
Posted on Mar 31, 2011
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Power door locks wont work on chevy colorado 2005
I really doubt one loose door latch will keep all the door locks from working . There are a lot of thing's involved in the power door locks ,relay's , wiring , master control switch etc..... Viewing wiring diagrams , testing electrical circuit's , PWR LOCKS 20A fuse etc....Are the power door locks and the driver power window inoperative?
Did you review the Power Door Locks Description and Operation?
YES - Go to Step 2
NO - Go to Symptoms - Doors
Verify that the power door locks are inoperative.
Do the power door locks operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring System
NO - Go to Step 3
YES - Go to Step 7
NO - Go to Step 4
Are the power door locks inoperative from a single door lock switch?
YES - Go to Step 5
NO - Go to Step 6
5
Is the driver door lock switch the inoperative switch?
YES - Go to Step 8
NO - Go to Step 9
6
Is the driver door lock actuator the inoperative actuator?
Test the battery positive voltage circuit of the drivers switch assembly for a short to ground or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 21
Go to Step 8
8
Test the ground circuit of the drivers switch assembly for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 13
9
Test the passenger door lock switch control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 12
10
Test the driver door lock actuator unlock control circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 14
11
Test the door lock actuator control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 15
12
Test the passenger door lock switch ground circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
13
Inspect for poor connections at the harness connector of the drivers switch assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the harness connector of the driver door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 18
15
Inspect for poor connections at the harness connector of the appropriate passenger door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
16
Inspect for poor connections at the harness connector of the passenger door lock switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
17
Replace the driver switch assembly. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Did you complete the repair?
Go to Step 21
18
Replace the driver door lock actuator. Refer to Front Side Door Lock Replacement .
Go to Step 21
19
Replace the appropriate passenger door lock actuator. Refer to Front Side Door Lock Replacement or Rear Door Lock Replacement .
Go to Step 21
20
Replace the passenger door lock switch. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Go to Step 21
21
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jul 17, 2012 | Chevrolet Colorado Cars & Trucks
I have a kenmore HE 2plus. i am getting a f-21 error reading and door won't unlock, what is the problem and how do i get the door open?
f 21 usually means drain pump is bad. may need to check door lock an see if it reads 15 ohms across the output. if its more than 15 change the door lock
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
During the cycle, it has stopped and the screen is flashing F- 21, what does that mean? The door is locked and when I do get the door open, water spills out. What do I do?
The drain cycle only runs for 8 minutes. F-21 is a blocked drain tube. Open the panel in the front bottom and locate the drain tube (front right) Disconnect it and you will find a little collection area in the tube as it first comes out of the washers tub. Clean it out and try resetting it to drain then all should be fine. I always find coins and other stuff like tissues blocking the flow.
Jan 20, 2011 | Kenmore HE2 Plus Front Load Washer
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
Colorado door locks
I had a problem where drivers window and door locks did not respond. I got them both working again by activating the 4-way flashers! This must reset something somewhere. This is the second time this has worked for me.
Mar 02, 2009 | 2005 Chevrolet Colorado
Door won't unlock
remove bottom panel reach up to lock area pull down on small tab to release door if tub has water in it remove pump filter aacess by turning counterclockwise (have towels handy dip out as much water as possible first)
Sep 09, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
