Question about Bosch Washing Machines
Machine is locked. Dont no how to unlock it. - Bosch Washing Machines
  • 822 Answers
If the interlock has packed in......it is posseble to open door by giving it a sharp clout with the palm of ya hand about an inch or so in from the door edge ............
cheers
Posted on Mar 31, 2011
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Hi, my washing machine Venus VW400E has been locked and i dont know how to unlock it. Please help me how to unlock it. Thanks
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 20, 2011 | Washing Machines
The remote locking for my 97 Audi A4 Avant doesn't work after I replaced the batteries. I've tried several bits of advice but none of them work.
with the key,unlock the drivers door and hold the key over(the windows will go down)wait 30 secs,then lock/hold the key over (the windows will go up)wait 30 secs then press/hold the unlock button on the remote,you have just reset the system.(if that dont work you WILL need to get the car onto a VW/AUDI diagnostic machine(dont bother with the mickey mouse type).
Nov 21, 2010 | 1996 Audi A4
Door won't unlock and cycle won't start
The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
May 24, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Door lock mechanism stuck in locked position with the door open. Can not close door. How can I unlock it?
sounds as tho you will need a new interlock unlocking it will not cure the problem. Easiest way to it is to undo the wire round the door rubber pull off the door rubber from front of machine undo door lock screws at front then you should be able to clearly see the lock dont take any wires off till you are absolutely certain of the exact place they came from.
Mar 31, 2010 | Whirlpool GHW9400 Front Load Washer
Will lock but not unlock
IF POWER LOCKS DONT LOCK ITS YOUR DOOR LOCK RELAY BAD.IF YOUR POWER LOCKS DONT UNLOCK ITS A FAULTY UNLOCK RELAY.
Sep 20, 2009 | 1997 Pontiac Trans Sport
Child lock
look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock
Oct 04, 2008 | Siemens Washing Machines
CYCLE LOCKED BUTTON WILL NOT SHUT OFF
Possible end of cycle signal control lock press and hold for 3 seconds to unlock control. Please reply if this does not work. Will provide further assistance.
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
