Question about Jensen JCR-560 Clock Radio
Cd won't play, it starts & stops spinning a couple times maybe then dispaly say 17, 16 or 15... thanks
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
Hi guys my technics sl-eh770 has started to skip and this can become very anoying. what would be a fix or do i have to get a new 1
if this is happening on all cds then it would indicate that your lens maybe dirty.
you can by cd cleaners discs that go into machine like a regular disc but when they play they rub the lens clean.
you should only try this one time if it still is a problem there maybe some dust in there getting in the way. this would need to be opened to check.
I hope this was useful.
Jan 24, 2011 | Technics Audio Players & Recorders
When a CD is selected, it's starts to spin, I hear 2 clicks and it stops spinning. This happens a couple more times then the CD is ejected and returned to it's slot.
It sounds as though either your CD player (probably a CDM3 or CDM4S) of the CD control box is defective. I would be happy to help you troubleshoot further over the phone and can provide repair and/or replacement of the defective components. Please email tech@wurlitzer-ohio.com. Thank you, Rod Stebelton
Jan 30, 2010 | Wurlitzer Jukebox 1015 One More Time...
My cdrom drive wont play any cd rom discs, it starts to make a noise then stops
The cdrom is surely bad, it is either you change it or you repair, the lense of the drive must have been damaged.
Sep 23, 2009 | Xcd ThinkCentre A51 Ultra Small Form...
CD starts to spin then stops
Problem lies in the optical block. try cleaning with a CD cleaner. Might help
Jun 16, 2009 | Bang and Olufsen Beosound 2000 Shelf...
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Missing segments on the display
LCD dispaly is standard,
the brightness is controlled on the display control baord mounted on the board that the dispaly cable plugs into, the gain of an op amp that controls the brigtness of the diplay is loacted on this board , check also the potentiometer located close to the connector and adjust that, but a quick visit to radio shack will get you a couple of cents worth of parts and a few mintes of delicate soldering and a couple of hours of dissasembly , tracing and reaasembly. with a risk of doing further damage.
equally likely to a faulty power op amp or potentiometer is that the dispaly is expiring ( it happens sometimes to these types of plasma displays.....)
so if you are determined not to get a cheap relapcement cd 20 and are determined to open the beast. get a cheap broken cd20 unit and take the dispaly out of that one and replace it with your display ( by display i specifically mean the intergarted circuit tht the plasma screen is mounted to, and subsequentially screwed into the inside face of the cd 20 unit behind that bit of smoked glass,
which of course you are going to open and clean before you put it all back together gain.
have fun ;-)
Dec 30, 2007 | Bose Lifestyle 30 System
Panasonic SA-AK330
Change the spin motor disc
Jun 08, 2007 | Panasonic SC-AK330 Shelf System
Jensen JCR-560 Clock Radio Logo
55 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
