Question about Microsoft Xbox 360 Console
360 turns itself on without me doing it, I turn it off and within seconds its switched on again?? any suggestions
  • 767 Answers
Your console seems to have a mind of it's own Problem.
The Ring of light P.C. board aka ( RF board ) is failing causing
the console to randomly turn of and on.
Goto ebay and buy an RF board .They cost about 10.00
remove ( open ) the case unscrew 3 screws holding the
RF board and simply plug the new one in and that's it.
If you have any questions feel free to ask.
Rob
Posted on Apr 01, 2011
Once the VCR is turned on, it turns itself off.
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Feb 16, 2014 | Panasonic PV-V4523S VHS VCR
The alarm system on my 2001 Volkswagen Jetta GL keeps turning on by itself
You must have the dealer keep the car until this fault occurs and then scan the security system to see what is causing the triggering of the security system. It is very possible that the drivers door ajar switch or latch switch is defective and it triggers a false tampering signal.
Sep 28, 2012 | Cars & Trucks
After 2 seconds my monitor HP w1907v is switching off itself and there's no way to bring it back to life again. If i switch off and on again the monitor shows images for 2 seconds and then dies. I...
Well the monitor obviously works, so I see no reason to open the case on the monitor especially because there are no user serviceable parts within the case. my sugestion is to try the monitor on another PC if that yeilds the same results then I am wrong and the problem lies with the monitor. I believe the are two types of connections for this monitor shane_barnha_2.jpg VGA and DVI shane_barnha_0.png
Next step is to try the one that you have not tried yet if that fixes it then the problem lies in the output conection on the back of PC the input connection on bottom of monitor or the cable itself. If there isn't a second connection like I think then the next option would be to try another monitor, which if you do not have available can be achieved by using most new flat screen TV's If you have a TV With the same conection Just move the PC or TV close enough to try, Use your remote to change TV input to PC then turn TV off connect cable turn TV on and start up your PC if this works you will need to have your monitor repaired or replaced.
Thumbs Up if helpful, Feedback is Appreciated!!!
Good Luck!!!
Jun 18, 2011 | HP w1907 LCD Monitor
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
I cleaned the Gpu,now everytime i turn on xbox 360 it overheats
One of the clamps must of came loose check them again.
Dec 31, 2008 | Microsoft Xbox 360 Console
I have the RX - V3000 Model. It turns on for a second and immediately turns off.
I had the same issue and tried changing inputs and etc. within a second of time. Nothing I did worked until, I opened the lower front access door and twisted the effects knob around quickly. This stopped it from turning off and it has been functioning normally since. Even turning it off and on again is without the issue coming back. I did try most all the buttons previous to doing the effects knob, in case that makes a difference in the long-run.
Before the issue you are having started on the unit I was working on, the owner of this unit did say he was having an issue earlier with the monitor SVideo jack in back, having a role in it powering off like this, about 6 months ago. To make it work then, he would remove the SVideo cable from the monitor jack, turn on the unit and then put back the SVideo cable once the unit was on and working. This allowed it to work for several weeks to a month before turning itself off again. He would repeat this procedure and it would work fine again for awhile.
Could be an electrical or grounding issue via SVideo that messed things up more and more?
Hope this works for you too!!
Nov 18, 2007 | Yamaha RX-Z1 Receiver
Microsoft Xbox 360 Console Logo
180 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
