Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
AEG Arctis freezer displays fault F7 and does not reduce the cabinet temperature.
3 Suggested Answers
buddymcl777
  • 67 Answers
SOURCE: Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
Posted on May 04, 2009
SOURCE: My AEG Arctis freezer is not freezing at the
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Posted on Apr 21, 2010
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Aeg arctis freezer
Check that the cooling pipes at the back of the freezer are not clogged with dust etc. and that there is sufficient space for air to circulate around them. If they are ok check that the freezer door seals are all intact and seal the freezer cabinet completely when the door is closed. Any gaps here will cause the compressor to over work in an attempt to keep the temperature low. If none of these suggestions then it could be a slow leak of the refridgent gas. A clue that this is the case is the freezer being a lot cooler at the top than the bottom of the cabinet.
Jan 06, 2014 | Freezers
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
My AEG Arctis freezer is not freezing at the correct temperature and seems to stick on -11 even if I put the fast freeze on.I have turned it off for 24 hours and on again but it still does not hold the...
Oct 05, 2009 | AEG 10.35 cu. ft. / 293 liter Upright...
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
130 people viewed this question
Top AEG Freezers Experts
Charles T Nevin
Charles T Nevin
Gil Shultz
Are you an AEG Freezer Expert? Answer questions, earn points and help others
