Question about Frigidaire Refrigerators
Model PHSCH39EGSS0 freezer wont freeze ice cream
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
How to set temperature for freezer part on Model GSH22JGCC BB What should it be
The best temperature for the freezer section is in the range of 0 F to -10 F. Ice cream will remain somewhat mushy at temperatures above about 5 F or so. Actually ice cream never does totally freeze due to the fat content.... it does get hard but does not totally freeze. Now ice on the other hand will freeze solid at 32 F , as you well know, the colder the faster it will freeze.
Mar 22, 2014 | GE Refrigerators
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream comes out fine at first the mashine doesn't cut off then it seems that the ice cream freeses in the cylinder to the point its to hard to come out
Use slightly warm ingredients or leave the freezer bowl out of the freezer for a few minutes before beginning - this will help if the rim around bowl freezes so fast that it stops the paddle from moving. When working optimally, I found that 3 different Cuisinart ice cream maker models will produce the best ice cream at around 14 to 20 minutes - no more than that. But it varies by your exact model #.
Jun 01, 2009 | Cuisinart DCC-2000
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Over freezing ice cream....
Any water is going to solidify the mixture. Make sure you use heavy whipping cream, and not half-and-half or some other substitute.
As far as the mixture freezing onto freezer bowl - use the supplied spatula to try to scrape it off, but I generally have to count that portion out as lost. Running warm water over it will quickly wash it off.
Happy mixing!
-Tha Mp3 Doctor
Jul 17, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
