Question about Arris DCT6200 DTV Receiver
I'm trying to connect my dvd recorder to my Motorola dtc6400 DVR. I can record picture but not sound because there is only one set of RCA audio outputs on the DVR and they go to the HDTV. There is also no coax out-going port on the DVR to connect it that way. Any idea how to connect it so I can record picture and sound?
  • happysahm123 Mar 31, 2011
    I do have a Digital Audio Output on the TV. The user guide with the tv says it's used to hook up a multichannel receiver. Would that work with the first cable you suggested?
    I think this is what I need if I can use the digital audio output but I need one longer than 6 in. Would be more like 3 ft. http://www.cablestogo.com/product.asp?ca...
  • 635 Answers
See if your TV has an audio out socket at the back. If so connect this aodio out to the DVR to record the sound . If not buy a pair of ( one for Left channel and the other for Right channel ) one is to two Y connector and plug the jack to the DVR and connect the split ends to the TV and Motorola DVR. That way you will have sound going to TV & DVR
Posted on Mar 31, 2011
    President:
  • 1,335 Answers
You could use a RCA splitter (1 in 2 out) adapter. Look at
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10429&cs_id=1042904&p_id=326&seq=1&format=2
This should solve the problem.
Let me know if you have any more questions. Thanks.
Please rate thsi solution.
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
What is the correct connections from the DVR to my DVD recorder so I can transfer recordings from my playlist to a DVD?
You should have RCA inputs on the DVD that are yellow, red, and white. The yellow for video, the red and white for stereo audio. All you have to do is have the video out from the DVR connected to the input of the DVD and then you should be able to record.
Mar 14, 2011 | Televison & Video
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
I have a DVR from my cable company which I recently replaced. I have the cable coming to the DVR, then out to my RCA DVD recorder, then out from the DVD to my Vizio TV. I have an HDMI cable connection...
IT SOUND LIKE THERE SHOULD BE AN INPUT BUTTON ON YOUR CABLE OR T.V REMOTE TRY CHANGING THE INPUT. ALSO TRY PLUGGING DIFFERENT AUDIO AND VIDEO CABLES BETWEEN RECORDER AND TV. ALONG WITH YOUR HDMI.
Oct 22, 2009 | RCA Televison & Video
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Will not show picture on disc
Check the RCA wire or fiber optic conection. If you use RCA wire be sure you put Video output from your DVD to input Video of your tv set.
Apr 16, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
May 28, 2007 | Pioneer DVR-520H DVD Recorder
Arris DCT6200 DTV Receiver Logo
265 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
