Question about Refrigerators
I purchased a 1988 trailer with a domentic RM 2607 model gas referigerator. The unit has been out of service for the last 4 years. I started the refrigerator on electric, it cooled with no problem for one day then the check light came on, I. switched it to off and back on it tried to light on gas but failed to for several tries. After the gas lines got purged it lite and switched back to electric.rhe check lite came on and the same thing happened again. while burning on gas I could hear a clicking noise like the igniter was trying to work. what might I look for to solve this problem?
  • 57 Answers
Don't know too much about those, but I will tell you what I know. It operates like a stove with a standing pilot light. Things get dirty and build up. Clean the end of the capilary that rests in the flame with steel wool. Give me a thumbs up if it takes care of your problem.
Posted on Mar 31, 2011
When main gas valve opens to start burners the gas pauses then ignites with a high volume woof.The pilot flame looks a little small could this be the issue. This unit is Brivis Buffalo year 1988 model...
The problem is called "Delayed Ignition". This can be caused by burner & pilot obstructions (dust, lint and/or pet hair) and needs to be thoroughly cleaned. At 23 years old, I'm surprised the unit is still in service.
Hope this helped you to troubleshoot and solve the problem.
Apr 28, 2011 | Heating & Cooling
F-defrost sensor error..Samsung referigerator less than 4 years old.. no local repair guys will even work on these units..800 number for samsung..they said unplug unit for 24 hrs and plug it back in...
The heater needed for this repair comes with an evaporator making this a major repair. What city are you in? I will try and locate someone for you.
If not I can help walk through the repair if you are really handy.
Apr 18, 2010 | Samsung Refrigerators
Dometic rm 2607 makes a gurgling sound when started in a/c or lpg . no cooling, in fact the inside of fridge heats up.help ? thanks
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
Jul 08, 2009 | Dometic CS-200 Wine Cooler
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
Apr 27, 2009 | Magic Chef 9122 Gas Single Oven
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
