Couple of years old . not old. Recently stopped completing cycles. seems to happen after the washcycle or rince, not sure. Need to manually turn over to spin and re-start machine. help!!
  • 4,340 Answers
Be certain BOTH fill hoses are turned on. What happens is hoses get reversed, and someone turns off the hot water (which is connected to the cold inlet) and the machine needs cold water on rinse, so it will JUST STOP and wait happily forever. Both taps on and then check for reversed hoses.
Posted on Mar 31, 2011
Drum stops turning after 2 turns
the belt could be slipping and worn out it could stretch after the first couple turns
Jul 14, 2012 | Washing Machines
My machine has recently started not completing a full wash cycle and seems to stop before the rinse and spin completion. It also shows a "nf" in the digital readout. any ideas?? Of course I cannot find...
Look carefully at supply water. sometimes hoses are reversed, dad wants to save money and turns off hot, but water is needed to finish rinse cycle....turn on both taps and test again.
Sep 06, 2010 | Maytag Washing Machines
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Our GE washing machine makes a horrible sound during the spin cycle. It is only a couple of years old. Everything seems to be working fine otherwise, just tremendously noisy during this cycle. This just...
you will need to take a look at the clutch which sits on the top of the motor. if it comes apart, and it can if the machine is overloaded, you will need to replace the clutch. once you remove the "clutch clip", it is horseshoe shaped, you will need to replace it. you cannot reuse it as it won't hold. hope this helps you.
Oct 14, 2009 | GE WBSR3140DW Top Load Washer
Lost manual, wheres rince aid comp
forget the built in rinse aid, it only works for a couple minutes during the whole wash cycle. go out and buy the rinse/aid or jet/dry package that hangs on the racks and works during the whole cycle. of course use only cascade powder soap and sparingly.
May 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Powerpoint dishwasher TW26
cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
May 02, 2008 | Dishwashers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Machine blocks at rince cycle
running empty or full makes no difference. problem may be not draining to test this, put some water in appliance from a jug then start the cycle. (first action is to drain) see if water disappears. get back to me if you wish
Apr 02, 2007 | Siemens WXLP1460 Front Load
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
