Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Linkage inside gear box does not engauge. Mechanics work to the bolt on top of the bottom gear (differential) box. Neither forward nor reverse work.
    Brigadier General:
  • 3,911 Answers
Most likely a hydrostatic transmission and most likely it is dead. Buy a new one or look around on google and craigslist for a used one. Maker and model number will be printed on top and possibly stamped on the bottom. New hydrostatic transmissions cost more than a new mower.
Posted on Apr 01, 2011
Get a limited slip differential stopp slipping in reverse?
limited slip differentials are so designed that when one axle looses traction the pressure is applied through the side gears to lock up diff so that both wheels have to turn. If it slips in reverse then in will slip going forward . I would be inclined to look for a reverse gear problem in the gear box/ transmission. If it is an auto check for reverse solenoid operation.
Oct 07, 2014 | Cars & Trucks
Why wont my 1986 f250 auto ****** not go into rev. or park
it sounds like you reconnected the linkage in the wrong position so it can still go into the forward gears but there is not enough cable length to allow for reverse and park to be engaged disconnect the linkage again and use trial and error to get it back to where you need it also the linkage should show you where the bolt was that tightened it but if you took it off and then moved either the linkage or the transmission gear selector arm on the transmission now its not in the position it was when you disconnected it resulting in this problem of no access to the other shifter points park reverse and you will have to check all gear shifts till you get it right but if it was in park when you took it off take the linkage off move the trans gear selector to park and reconnect it where the old marks are and you should be O.K.LATER MAN!
Aug 21, 2014 | Cars & Trucks
How to Change the impeller on Suzuki 140 outboard motor
Suzukis are normally a mission to work on especially if it is a two stroke,so I suggest you get a workshop manual.all gearbox bolts must be undone,the gear linkage is under the bottom carb,this is the tricky part,you have to loosen a nut at bottom of gear arm where gearcable fits,then push in with screw driver,this releases gear change shaft.the biggest problem is trying to see what you are doing.good luck
Oct 08, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
91 Chevy beretta clutch is fine but shifter is loose like the linkage is broken. Do not know where to start looking. Took the console out and got underneath but really do not know what I am looking for....
GENERAL MECHANICS do, Start working around the Shift Handdle by removing the cover (liffting around the rod) you may end up openning 4- 8 bolts to remove the Gear Box upper shaft cover to inspect the shifting fork.
Mar 07, 2013 | Cars & Trucks
Shifter is erratic. wont start in park. drives forward when shifted to reverse, sometimes drives forward when in park. sometimes reverse is neutral (which is good so it will start!!!) what is going on???
It sounds like the linkage at the transmission has come loose. Have someone get inside and move the shift lever from gear to gear so you can see where the linkage is on your transmission. You'll have to climb under ypou truck to see this, on the drivers side. check to see that all the bolts are tight. Your switch that allows you truck to start in Park or Neutral is located there.
Oct 25, 2012 | Dodge Ram Pickup 1500 Cars & Trucks
Why doesnt my car go in reverse the reverse lights go on and it kicks but no movement
if you have an automatic gear box , then it is very possible that you have reverse band is broken inside gear box , , light will come on because switch for reverse lights may be actuated by shift lever not gears .
there is a foward band and reverse band in auto gerabox's so if you are able to drive forward this gearbox will need to be repaired or replaced .
if manual gearbox , you may find a reverse linkage loose , or gears dammaged in gear box .
good luck hope this helps
Nov 10, 2010 | 1994 Nissan Sentra 4-Door
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
NO REVERSE, FORWARD GEARS IN REVERSE
i think you meen you only have reverse and no forwards gears?
if so its likley to be the linkage for forward gears look at the gear box to see if any thing is hanging off a cable or push rod it could also be up in the car under the gear leaver
Oct 30, 2009 | 1995 Jeep Grand Cherokee
Goes forward in all gears but not in reverse. If put in nuetral it still won't go back it is like the brake is on. Don't know how to check or fill the oil in the rear differential either.
pull top off of transmission and see if any thing is broke or jumped out of shifter linkage pull top plug out of 1/2 to 3/4 up from bottom fill until overflow
Sep 12, 2009 | 1991 Ford Explorer
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
262 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
