Question about Price Pfister Single Lever Handle Faucet CHROME
My price pfister single handle shower/bath control cartridge needs to be replaced. I've removed the retaining nut, but I've been unable to remove the retaining ring that holds the cartridge. My device is approx. circa 1985. Can you help?
    Master:
    Sergeant:
  • 500 Answers
There may be 2 pins if under ring the collar has multiple holes.remove pins & unscrew ring... or it could be just stuck from age..
Posted on Mar 31, 2011
  • swhitecat Mar 31, 2011
    I guess it's not a comment, but rather a question. What sort of tool would I use to remove these pins?
  • Mot Smith
    Mot Smith Mar 31, 2011
    Small hook tool very pointed or a strong needle .small needle nose plyers.. possibley a magnet..
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
I have a price pfister a112.18.1 shower only (no tub), single-handle. It is leaking from the shower faucet. How do I repair?
You have to turn water off to shower and remove handle then cartridge lock ring then there are two washers and srpings that can be popped out with small screwdriver.Lowe's has replacement springs and washers ,be sure to mark position cartridge was because that is very important to reinstall the same way it came out.
Jun 09, 2011 | Price Pfister Plumbing
My x08 shower is leaking. I replaced the mixing cartridge O-ring, and that did not fix the leak. Today I replaced the 2 piece assemble with the one piece upgrade part 974-042, but it is still leaking, so...
Replaced Price Pfister hot water cartridge but it is still leaking! I removed several times and flushed the line then replaced without solving problem. Help!
Apr 27, 2011 | Price Pfister R897EBK Brushed Nickel...
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
Shower head slow drip when valve close
You need to rebuild the cartridge. There are small o rings inside and dirt and other particles in the water tear them.
TAPE OVER THE DRAIN UNTIL FINISHED.
Turn off the water, pull the handle, unscrew the retaining portion of the bezel usually with thumb traction ribs. THe whole plactic part pulls out. Take this with you to a plumbing place, and likely you can get one for free...
Alternatively, you can call Price Pfister, and they well likely send what you need to your door...probably for free...
Mar 08, 2011 | Price Pfister R897EBK Brushed Nickel...
How do i install a new cartdridge for a delta single handle faucet in my tub
Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
May 31, 2010 | Delta & Single Handle Shower Faucet
I cannot get the water to turn off no matter how far i turn the handle
Once your cover plate is removed you can access the cartridge. With different styles by Price Pfister there maybe an additional pressure balancing part behind the cartridge. If so they should both be replace at the same time. Remove and take to your local plumbing parts store for a match up.
Apr 26, 2010 | Price Pfister R897EBK Brushed Nickel...
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister Single Lever Handle Faucet CHROME Logo
459 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
