Question about Microwave Ovens
The microwave will turn on allowing the carousel to turn but will not heat item. Also makes a buzzing sound. Toaster still works.
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and should be directed to an authorised repair agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 31, 2011
Carousel stopped turning
see this causes and fix it. God bless you
ough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly
Sep 24, 2012 | Tappan Microwave Ovens
Magic Chef MCO160UQ Carousel turning slowly
The turnable motor is going, the buzzing indicates the magnetron is about to fail. I suggest using the microwave oven until it dies and replace it, not cost effective to repair.
Apr 14, 2012 | Magic Chef MCO160UQ Microwave Oven
The oven goes on, carousel and timer works, but no heat. The oven felt warm on sides at first. Unplugging it, waiting awhile, turning it on did not correct the problem.
The magnetron circuit has failed. If it makes a loud buzzing sound when you operate it, means that the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to get it fixed. Sorry.
Apr 15, 2011 | Sharp Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Toaster Master 1979 has less power
Because the microwave energy is beamed into the interior of the microwave and then dispersed by a metallic "stirrer," the pattern of the energy can be fairly consistent, rather than completely random. But this pattern sometimes causes certain portions of the food to overcook (creating tough spots) and others to undercook. A microwave oven with a carousel is far better at cooking the food consistently--the pattern becomes quite random while the carousel is turning.
Nov 13, 2008 | Microwave Ovens
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic NN-S541 Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
