Question about LG Refrigerators
Motor making a noise when defrosting and icing up in the back of the freezer. only 2 yrs old
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Have a strange noise coming from freezer but ice cube maker not hooked up. sounds like a making ice, coming from the fan porttion of freezer Serial number 54815720jp Bought it in 2007
You might have ice building up around your fan or in the back of the freezer. If that is the case, then you have problems with the defrost circuit (defrost heater, defrost thermostat or defrost timer).
Suggest you open up the back panel of the freezer and see what is going on back there, before you have to replace the fan and motor.
You have to take the food, and then the shelves out and then take the 2-4 screws out of the back panel and remove it. If there is ice buildup then you will need to defrost your freezer and then troubleshoot the defrost circuit to determine what part has failed. The good news is that you will be able to order the parts and wait for them to arrive since you can use your refrigerator for awhile before the ice becomes a problem again.
Jul 28, 2011 | Amana Refrigerators
My refrigerator is making a loud purring sound. What can I do to make it stop?
It is so common that the fridge can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that fridge is vibrating when it is running then the compressor motor fittings has to be inspected. check the mounting of the motor , check for SYMPATHETIC vibrations to the plastic body /rear covers that can produce these loud purrings. If so tighen the clips or use some rubber damper sticker- one side sticker with padding- so as to reduce the vibration and noise.
Jul 13, 2011 | KitchenAid KSSC42FMS Side by Side...
Rsh1dbrs - freezer fine, fridge now emitting loud 'slow fan' noise after opening /closing. just under 2 yrs old - no problems til now.. cleared it out & looks like ice build up at back ? any...
Check for ice build up in the freezer section. Sounds like a defrost problem .You will need to remove the panel in the freezer and look for ice build up, from there you could have 3 or 4 different parts that one or more has failed
Jul 08, 2011 | Refrigerators
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Freezer is icing up. Unit is about 2 yrs old
You need to check out the back of the freezer. At the current status, it may be locked with ice. Have it defrosted or just have it melted away. Clean the coils and the entire unit. Either the drains were blocked by food debris or dirt causing water to accumulate and ice to form or the thermistor has been iced or is faulty or too much ice accumulated in the unit's coils.
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Our Subzero 561 ( -15 yrs. old) just started making a rattling noise. It sounds like a fan is hitting ice. It stops when we open the freezer door. When we look up in there, ice is caked on. What steps...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Refrigerators
Loud Freezer Motor noise
I don't usually buy the service plan but I did for this unit (hey it's gen 1). The service guy said he has seen this problem quite a bit and that LG created a new RCM board to fix it (part# BBR34917104). Apparently the OEM board didn't detect the ice build up on the fan motor very well. I had the new board installed two days ago and defrosted the freezer. So far so good, I'll post again if I have any further issues.
Dec 27, 2007 | LG LFX25960 Bottom Freezer French Door...
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
53 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
