Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Defrost solution didn't last....
I appreciate your help so far on my bottom freezer Kenmoore. You helped me out a few weeks ago and the defrost seemed to be occuring, but did not last. it has been 2 weeks and the coils are frozen solid again. the defrost is not happening. I turned the defrost timer 1 click and ultimately didn't change anything. it cooled for 2 weeks and then froze. you finished the last thought talking about replacing the heater circuit. which part would you suggest? you said it was probably not the defrost timer...maybe the heater/evaporator? I want to replace the correct part.
what other info might be useful in helping me figure this one out?
thanks in advance.
  • 828 Answers
If it does not defrost after turning the timer then the problem is further into the defrost circuit. If it does defrost when you turn the timer and that is the only time it does defrost replace the timer.
Posted on Aug 06, 2008
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
I have a kenmore refrigeator with bottom freezer. #596628322200, made by Amana. I bought it used two weeks ago from a dealer. The top started getting too warm a few days ago. The Freezer was fine. I...
Hello, Thank You for using FixYa. I will be helping you today.The defrost timer is on bottom behind the front kick plate. Open freezer door remove lower grille or kick plate and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Frost built up all down the back wall of freezer and temp is down
I just had the same problem a few weeks was the defrost motor in the is a quick fix..until you can get it fixed...turn it off...get it defrosted...all ice gone...and the defroster will work again...if you have one of those steam cleaners..that will defrost it fast!!!
Mar 30, 2009 | Refrigerators
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
