Question about HP DeskJet F380 All-In-One Printer
HP PRINTER I WOULD LIKE TO KNOW WHERE THE INKS ARE PUT IN THE MACHINE
  • 659 Answers
Hey there here is the setup guide wich will help you solve this issue good luck
http://h10032.www1.hp.com/ctg/Manual/c00656606.pdf
Posted on Aug 05, 2008
HP Deskjet F4280 is not printing quite the same colours as shown on the screen (which are the correct colours). They are coming out slightly too yellow. Can I adjust the printer to correct this?
Follow this steps for print quality issue...
Solution #1 Manually clean the inks.
  1. Please make sure that the printer is on.
  2. Open the ink cartridge access door.
  3. Take out all the inks on the printer on the printer.
  4. Get a clean wet cloth / cotton swab.
  5. Clean the electrical contacts of the inks using the clean wet cloth (electrical contacts is looks like a copper) .
  6. After cleaning it with the wet cloth, dry the contacts using a clean dry cloth.
  7. Put the inks back in to the printer.
  8. Close the cover.
  9. If the printer is asking you to do something, please do it.
After all the prompts on the printer, please make some test by making a color copy on the printer itself. If you notice that you have a good quality, you don't have to do anything but if you are still having issues with it, please proceed to the next step.
Solution #2 Power Cycle the printer.
  1. While the printer is on, unplug or disconnect the power chord at the back of the printer.
  2. Wait for 1min.
  3. Plug the power chord back in.
  4. If the printer is not turning on, press the on / off button to turn it on.
If you are still having issues (encountering some error messages on the printer or on the computer) please let me know by replying to this post.
Good luck :)
Feb 17, 2011 | HP DeskJet F4280 All In One Printer InkJet
Hp psc1610 all-in-one after market ink cartridge problem
The following cartridges are supported by your product
black inkjet print cartridge - HP 94
tri-color inkjet print cartridge - HP 95
tri-color inkjet print cartridge - HP 97
photo inkjet print cartridge - HP 99
May 19, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Brand new L7680. Just set it up with the software and the screen is showing a failure signal 'Alignment failed. Refer to device documentation for details. All that says is run the process again. I have, 5...
This not an issue w/ the software. please follow these steps...
Solution #1 Clean all the inks
  1. open the cartridge access door.
  2. take out all the inks that you have on the printer. (put them on the table upside down)
  3. get a wet clean cloth.
  4. on each cartridge you need wipe it out the electrical contacts on the ink cartridge it self.
  5. put the inks back in to the printer.
  6. close the cartridge access door
  7. turn off the printer
  8. unplug/disconnect the power cable
  9. wait for 1min.
  10. plug the power cable back in back in to the printer.
  11. turn on the printer.
  12. access the setup menu (press the wrench icon on the printer or setup button)
  13. Go to tools, then look for clean printhead
  14. align the printer.
Solution #2 Clean the printhead manually make sure that the printer is on.
  1. Open up the cartridge access door
  2. Take out all the inks that you have on the printer. (put them on the table upside down)
  3. Once you have take out the inks.
  4. Take out the printhead (printhead is the one that holding the inks)
  5. look for the printhead latch. (pull it up)
  6. Take out the printhead.
  7. Clean the electrical contacts of the printhead using a wet clean cloth again.
  8. Put the printhead and the inks back in to the printer.
  9. Close the cartridge access door.
  10. turn off the printer
  11. unplug/disconnect the power cable at the back of the printer.
  12. wait for 1min.
  13. plug the power cable back in to the printer
  14. turn on the printer.
  15. repeat cleaning and aligning the printer by going to tools under setup menu (wrench icon).
Solution #3 Reset the Printer
  1. While the printer is on unplug the power cable at the back of the printer
  2. On the printer press the # and number 3.
  3. keep on pressing for 1min.
  4. After 1min. plug the power cable back in to the printer.
  5. If the printer is not turning on press the on/off button.
  6. You should get a message "part NVM reset" , then follow the following task. (cleaning and aligning printer).
If you still having issues w/ it call HP printers support department 1-800-474-6836
Good luck! :)
Jan 31, 2011 | HP Officejet Pro L7680 All-In-One Printer
Error Oxc18a0001 System will not let me print says original cartridge bl., lt.bl. (just replaced), red, yl., need replaced but when checked still have lots of ink in them. & keep getting flashing...
Follow this steps..
Reminder before troubleshooting ...
Make sure that the printer is on. Make sure that you are using HP genuine ink cartridge. Be careful of cleaning the inks and touch w/ your fingers, its very sensitive!
  9. wait for 1min.
  12. wait for 1min.
Good luck! :)
Jan 31, 2011 | HP Office Equipment & Supplies
Hp Designjet 500 not recognising ink cartridges. the ink carts were nowhere near empty but coming but the printer says replace bought new ones and put them in and the machine is not recognising them...
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Jul 15, 2010 | HP DesignJet 500 InkJet Printer
Do i have to put both color and black ink cartridge to make printer work hp deskjet 6122
Hi There
Yes you have to have all the inks in for it to work, the printer knows if 1 of the inks is not in.
Take care all the best Pineworks
May 06, 2010 | HP DeskJet 6122 InkJet Printer
Need to clean printer head but hp director incompatible with windows vista. can head be cleaned manually? If so please give instructions.
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Compatible inks v genuine HP inks?
Generally speaking the remanufactured carts have a lower capacity than the hp counter part. Otherwise they usually don't leak unless you go really, really cheap on it.
Jan 02, 2010 | HP Photosmart C8180 InkJet Printer
Don't acept cartrige of ink. Allthe time the
this happens when you insert fake cartridges in HP. usually i think higher products of HP dont accept fake cartridges.
Go for vivera inks. they are genuine HP inks.
or look out for pin in the cartridge area. as it may not be settled properly
Dec 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
