Washing machine stopped working showing f-01 - Washing Machines
  • Washing Mach... Master
  • 8,220 Answers
My washer will not drain
Click the link below for washer not draining and other washing machine issues:-------http://washingmachineforum.blogspot.in/2012/01/my-washing-machine-wont-drain-water.html
---------Thanks.
Feb 04, 2012 | Kenmore Washing Machines
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
Jan 29, 2011 | Hotpoint Washing Machines
Hi, Bosch WAS28720FF/01 Washing machine sometimes empties and sometimes does not. "Pump blocked" is the typical error message. Pump and drain tube have been inspected and cleared, and there is...
Bosch WAS28720FF/01 Washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 01, 2011 | Bosch Washing Machines
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
F 01 code won't come off, washer won't start
change control module remove top right front corner white or gray box
Aug 27, 2008 | Washing Machines
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
