Question about Garden
I have a samsonite padlock with a four digit lock. Unfortunetly I forgot the numbers to open it. it says TSA -005 on the bottom. Is there any way to get the necessary numbers to open the padlock?
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
Obertelli
  • 3006 Answers
SOURCE: TSA locked our TSA002 lock on our samsonite bag
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Posted on Oct 23, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
kirkx
  • 2019 Answers
SOURCE: I need to open a
The patent number does not help at all, because it is the same on all luggage by Samsonite.
If you could find a serial number that was unique with each piece, that could possibly cross reference a combination, but not likely.
Posted on May 09, 2011
My samsonite luggage with a four digit lock was opened by US customs and since then the case can be opened by pushing the open button whatever digits appear on the lock. Can this be fixed?
Most likely they pried it open and snapped the locking mechanism inside. Definitely not repairable, but you might be able to replace the entire combination lock. If you think the luggage is worth the expense, you could send it back to the manufacturer for repair.
It is usually unwise to lock suitcases these days when traveling by air. Especially on international flights. It's better to just use a zip tie, which can be cut off easily without damaging your luggage. That way you can tell that your suitcase has been tampered with (Cusoms & TSA will usually tag it anyway), so you can make sure nothing is missing, but avoid damage to your luggage or locks. Those locks don't really provide any security anyway.
So, if the latch still works, leave it alone and use the zip ties (through the zipper pulls) the next time you travel.
Aug 28, 2017 | Samsonite Photography
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
How to change code on master tsa007 lock
That number has nothing to do with the lock. That is the key number for TSA to open it. You will have to contact the maker of that lock or since they are not expensive, purchase another one.
Apr 25, 2014 | Samsonite Tripod
Open samsonite tsa007 lock
That number is the key number that TSA uses to open that lock. There is nothing available except to contact the maker. If you would rather replace it, they are not expensive.
Jan 14, 2014 | Samsonite Photography
How to unlock samsonite combination lock?
1. Call Samsonite Customer Service at 1-800-262-8282. Representatives are available Monday through Friday from 10:30 a.m. to 5:30 p.m EST.
2. Press "1" and then "6" on your telephone keypad to speak with a representative to order a replacement key or padlock.
3. Pay the required fee. Samsonite will then send out the replacement key.
Aug 17, 2012 | Samsonite Tsa Acceped Padlocks Allow You...
TSA locked my luggage after searching and I dont know the combination
Hello; The only the thing I can say is take back to the airport make TSA open it or a profesional lock smith that will cost you. If the airport is not to far away Id carry it back to TSA
Aug 30, 2011 | Samsonite Tripod
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
1. Get a locksmith;
Oct 23, 2009 | Samsonite Tripod
Apr 11, 2009 | Samsonite Tripod
Forgot my 3 digit number lock on my samsonite bag
Sep 17, 2008 | Samsonite Tripod
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
