Question about Cameras
Inserted new batteries and now it will not start back up when the on/off button is pushed.
  • 58 Answers
Check for the batteries to be the proper ones adn also to be allgned with the +/- signs indicated on the battery cap one must be wit the + up and the other one must be with - up
Posted on Mar 31, 2011
The battery was changed on my car. after new one installed the alarm went off. the guy push the black button and turned the key. now the alarm wont work. how do i get it workind again? .
the guy pushed a button under my dash turned the key and car started
you need to know where that push button is under the dash
if you cant find it your self ... ring the place back for instructions
not nice but
you may have to get them to call out and show you or
tow the car back to where you got the battery fitted
Oct 11, 2016 | Cars & Trucks
2008 Altima with push button start. Why won't the fob unlock doors?
Insert key into and remove it from ignition more than six times in 10 seconds. When the hazards lights will flash twice insert key into ignition and turn to ACC position.
Then push any button on key fob once, the hazard lights will flash twice. Then open drivers door to END.
Should be all working again.
Jun 06, 2015 | 2008 Nissan Altima
Maxima starting problem
IS I-KEY BATTERY GOOD? IT'S INSIDE OF KEY FOB.
SHOULD BE SLOT LH SIDE OF DASH, INSERT KEY FOB
AND PUSH START BUTTON.
Dec 27, 2013 | Cars & Trucks
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
How do i open a new palm phone to insert batterys
To open the back casing to access the battery:
- Using your thumb, push down & hold the [[[[[]]]]] shaped button on the bottom of the phone
- With your other hand, pull the back casing away from the body of the phone
- To put it back on, just line it up and snap it back into place
Hope this helps!
Mar 04, 2011 | Palm Pre Cell Phone
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Have tried following instructions but cannot get back off to insert battery - nothing budges and am reluctant to push/slide cover too hard. Is there a trick to this?
There is three tangs that hold the battery cover in place. You can push with 2 fingers on each side at the bevel area on both side of the camera len. You could also bring you phone to your local service provider to ask them to remove the cover for you.
Oct 11, 2010 | Nokia 2720 Fold Cell Phone
It doesn't come on its an mp3 player and its not compatible
Hello
Verify that theplayer has a battery installed if it won't respond to you pushing its power button. Remove the battery cover on the back panel of the device. If no battery is installed, insert a new AAA-sized battery. Insert the battery according to the "+" and "-" symbols listed on the player's battery compartment.
Replace the battery if one is present and the player still won't turn on. The existing battery may be dead. A new battery will provide approximately 18 hours of continuous playback before it needs replacing, according to creative
Contact Creative's customer toll-free support line at 800-998-1000 if you still cannot get the device to work. Your Zen MP3 player's hardware may be broken and need servicing or replacement.
Sep 02, 2010 | Creative Labs Zen Micro MP3 Player
Rf tech 433 mhz
I had the same problem and finally found my manual. Here's what to do, everyone!
1. Take back panel off the sending unit, where the three batteries are, by unscrewing the 4 phillips head screws (assuming you, like I, had put the screws back in after installing new batteries). You will see a little gray button in a hole above where the batteries are; the little button is one you can push down with the same phillips screwdriver you took the 4 screws out with - don't do this yet.
2. Now, hold down the "channel" button on front of receiver panel for 2 sec, until the dash in the "ch" box and the place where the temp is supposed to be starts blinking.
3. Now, while these indicia are blinking on the panel, push the little gray button down and hold it for 2 seconds. This causes the transmitter to "register" with the receiver. You should now see a 1 in the "ch" box and get a temp reading.
4. Put screws back on, put receiver where you want it, proceed with rest of your life.
Feb 21, 2008 | Computers & Internet
Logitech Cordless Rumblepad 2 connection problems
 The 5 + 7 buttons work for teh OLD versions that take FOUR batteries and have the RED Logitech logo.
The New versions, which use TWO battreies has an ORANGE logo use buttons 6 + 8 to reset sticks.
Whatever postition the sticks are in when that battery is put back in will be condiered new calibrated center.
From Logitech:
To re-calibrate, please do the following:
Remove one battery.
Hold the six (6) and eight (8) buttons simultaneously while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated.
Jan 01, 2008 | Logitech Cordless Rumblepad 2 Vibration...
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
