Question about Sharp Office Equipment & Supplies
Sharp AL-1655 CS copier - machine is 4 years old and has new TD cartridge. It was dumping excessive toner which I cleaned up. Also, made grinding noise. When machine opened and TD cartridge removed, I found a very thin strip of metal approximately 10 inches long and 7/16th inches wide which has wire mesh screening running its length and two thing wires running the length of the screening. After removing it, the grinding stopped, but the pages stopped getting any toner. In other words, no printing on the page when it goes through. No error codes are shown. Can I replace the metal strip and will this solve the problem? Is it part of the fuser?
  • Sharp Expert
  • 1,326 Answers
The part that you are talking about is not from the fuser unit. It is from the drum unit, it is most likely the primary charge grid. It is part of the drum that charges the drum..... You may just want to replace the drum unit..... If the grid fell off the plastic holder may be broken... Good Luck
Posted on Apr 01, 2011
Noises on power-up.
emty waste toner and clean
Apr 22, 2010 | Sharp AL 1631 Copier
The printer says to replace the td cartridge and we just replaced it with a remanufactured one from Staples. The copier is a Sharp AL1655 CS
You may have just answered your own question.. Did you follow the instruction and take off all the tape.. Also, need you shake the cartridge side to side to looosen up the toner... If that does not work.... You know what to do
Apr 07, 2010 | Sharp AL 1631 Copier
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
The lamp scanner bulb broke. I have a Sharp AL 1655 CS
look for the sharp dealer in your area, we have one here in the Philippines.
Mar 17, 2010 | Sharp AL-1655CS Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
My sharp al 1655 says replace td cartridge. what is this?
It means that you should replace the toner and developer cartridge.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
I replaced the Sharp AL-1642CS TD toner cartridges twice. Still flashes the toner symbol. Someone mentioned cleaning the toner sensor. Where is the toner senor located? drjanisch
Where the toner bottle inserts into the holder, make sure the OLD bottles nipple is not stuck in there, this issue will not allow the new toner to flow into the system and the machine thinks it has an empty bottle
Apr 04, 2009 | Sharp AL-1642CS Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
171 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
