Question about Canon Office Equipment & Supplies
I got a message which read "The waste ink absorber is full." What is this, where is this and how do I replace it? Thank you.
  • bobtriplett5 Aug 22, 2012
    The carriage that holds the cartridges is under the edge all the way to the right so I can't remove the cartridges. Any suggestions
  • 4,323 Answers
Hi
Ink absorber (waste ink pads) is a sponge pad that is located under the chamber where you insert the cartridges. You can locate the waste ink pads to the right of the cartridges. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. Another thing you can do is to completely replace the waste ink pads or maybe take a hot water towel and clean it till the time you see no ink residue on the towel & then let it dry out.Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". ...
Dear miggsy,
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon Inkjet Printer Forum
Dec 05, 2008 | Canon Office Equipment & Supplies
Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Dec 22, 2007 | Canon PIXMA iP2000 InkJet Printer
183 people viewed this question
old marine
old marine
