Question about Yukon 24021 Monocular
Not switching on have replaced battery but still not working
    Master:
  • 577 Answers
Hello, take some switch cleaner--Radio Shack- and spray just a small amount into the switch. Did you installed the battery correctly with the polarity be correct. Does the battery compartment have any type of corrosion? If this does help then there is something else wron with it. stewbison
Posted on Aug 15, 2011
Replaced coach batteries and still not working
There is a relay that operates when you hook up to shore power that switches from battery power to converter power. It also charges the batteries. If you do not have battery power then suspect a faulty relay. It is located inside the power converter.
Aug 15, 2016 | Thor Motor Coach 2014 Windsport 32A
Winshield wiper delay intermitent module making noises
The wiper delay is in the steering column. It's a small box about 2 x 2 inches with a wiring harness attached. With the testing procedures I found below, you should be able to figure it out. I found wiper delays on eBay for around $10 to $20. Good luck.
WINDSHIELD WIPERS CHEROKEE, COMANCHE & WAGONEER 1. POWER INPUT Remove circuit breaker. Test battery side of circuit breaker. If battery voltage is not present, repair open to splice. Test across circuit breaker terminals. Tester reading should be zero (0) ohms. If not, replace circuit breaker. 2. GROUND Connector A unplugged. Test terminal G. Tester reading should be zero (0) ohms. If not, repair open to ground. 3. INTERMITTENT WIPERS Ignition switch in ACCY. Remove delay module and plug connectors together from the module. If wiper operate in LO and HI speed modes and mist (washer) is working, if wipers and mist operate, replace intermittent module. If not go to step 4. 4. WIPER/WASHER SWITCH Ignition in RUN, wiper switch position as indicated, back probe switch side of connector A for standard, connector B for intermittent: Test connector terminal E-wiper switch in LO and mist/intermittent. If battery voltage is not present, replace switch. test connector terminal C-wiper switch in HI. If battery voltage is not present, replace switch. Test connector terminal F-wiper switch to OFF. If battery voltage is present until wipers stop and then voltage drops to zero (0), system is working fine. If this does not occur, replace switch. 5. INTERMITTENT WIPERS Connector B unplug. Test across terminal A and D while rotating switch from minimum to maximum delay. If tester reading is not between 0-500 ohms, replace switch. Test across terminal A and G while rotating switch from minimum delay to maximum delay. If tester reading is between 0 and 500 ohms, replace wiper module. If not replace switch. 6. WIPER MOTOR Ignition in ACCY, wiper switch position as indicated, probe connector D. Test connector terminal 1. If resistance is no zero (0) ohms,repair open to ground. Test connector terminal 4-wiper switch in any position. If battery voltage is present, replace motor. if is not repair open from fuse panel. Test connector terminal 2-wiper switch in LO. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 2-wiper switch in HI. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 5-wiper switch OFF with voltmeter connected. If battery voltage is present until wipers stop and then voltage drops to zero, system is OK, replace motor. If not, repair open from wiper switch.
Found on the web. I hope this helps.
Rich Long
Jan 26, 2014 | Jeep Cars & Trucks
Battery disconnect switch not turning on & off properly
i am a tech at a ford dealership. it sounds like you have a short some wheres around your steering column that maybe what we call "backfeeding" to other systems. the area where the tilt is on the steering column is a good place to check. also remote starters can cause alot of havoc on a vehicle.
Oct 21, 2012 | Cars & Trucks
99 chevy dash,parking running lights don't work!
did you replace the dimmer switch on the dash by the headlight switch
Aug 26, 2012 | Cars & Trucks
Thermo fans won't work
if fan works at battery but doesn't when installed check for shorted out wire (grounding out) between switch and battery or possible the switch is burnt out or not making or braking contact (bad switch replace)
Nov 12, 2011 | Cars & Trucks
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have a GE 7-Day in-wall Programmable Digital Timer Model # 15086 which I installed about a year ago and was working fine until a few days ago. The screen went blank and the unit does not work. It acts...
The battery is not easily replaceable. It's a 1.2 volt, 80ma Nickel-metal hydride battery, that is soldered to the circuit board. I opened the back of the switch to find the battery. The one in this switch was in bad shape. It looks like the battery broke apart, but wasn't leaking. The switch is less then a year old. Bad design.
I just opened this up today and am going to look for a replacement battery. But soldering will obviously be involved to get the a new battery back in place.
Jul 30, 2010 | GE Hardware & Accessories
We have 3 Intermatic TB121C timers. 2 of them stopped working yesterday; the switch will no longer turn the lights on or off. We were not using the timer function at this time,just the switch. The display...
Yes, replacing the batery is each unit should get them working correctly again. The way these Intermatic timer switches work is that the battery actually operates the switching function to turn it OFF/ON. So once the battery goes dead, the switch won't operate properly.
You may have to reprogram your timer too, since some models lose their memory, once the battery goes dead. There are some new versions of Intermatic timers that use a semiconductor to hold the programming even in the event of a power loss or removal and replacement of the battery. (just an FYI for future reference).
Hope you find this Very Helpful and best regards!
Aug 12, 2009 | Intermatic Hardware & Accessories
Keeps saying replace battery
What kind of camera do you have?
Jun 11, 2009 | Cameras
Casio Pocket Viewer PV-S400Plus not working
When batteries are to be replace you must move the switch on the back cover to "replace batteries". After you replace the batteries, you must move the switch back to "normal operation". The unit will then want you to touch the dots in the cross hairs and then ask you to adjust contrast. Try replacing the batteries again with a fresh pair. If this does not work, open the cover with the switch in the "replace batteries" position and use your stylus to press the "P" button underneath the battery cover and try again. If this fails, try resetting the unit.
Jul 25, 2007 | Casio Pocket Viewer PV-S400 Plus Handheld
Yukon 24021 Monocular Logo
205 people viewed this question
Top Yukon Optics Experts
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
