Question about Kyocera FS-C5015N Laser Printer
Call service 0420:0007741 on printer display window
Hp c6180 all in one printer displays error 0x000000aa is there a fix for this
The names of places on your computer may vary depending upon your version of Windows but you essentially have to do the following...
-Go to "Devices and Printers" right click the printer and select "Use Printer Offline"
-Stop the Print Spooler Service. The rough path for this is as follows:
Start>Control Panel>Administrative Tools>Computer Management>Services and Applications/Services
-Now double-click Print Spooler and click Stop
-Now click Start
-Now right click your printer again and select "Use printer offline" again
The error should now be history.
Dec 01, 2012 | Office Equipment & Supplies
My Officejet Pro 8500 Wireless will not print in landscape mode no matter what I try. Last time I had this problem, HP had me install a generic printer; but I don't remember what exactly I had to do...
here's how:
FOR WINDOWS XP:
  1. Click Start .
  2. Click Printers and Faxes folder.
  3. Click File . Then select Add printer . NOTE: This step launches the Add Printer Wizard .
  4. Click Next .
  5. Uncheck the Automatically detect and install my Plug and Play printer checkbox.
  6. Click Next . The Select a Printer Port window displays.
  7. Click Next . The Install Printer Software window displays.
  8. Select HP from the Manufacturer list .
  9. Select hp deskjet 990C model from the Printers list.
  10. Click Next . The Name Your Printer window displays.
  11. If the printer name is correct, click Next .
  12. Click Next . The Printer Sharing window displays.
  13. Select No when the message Do you want to print a test page displays.
  14. Click Next . The Completing the Add Printer Wizard displays.
  15. Click Finish . NOTE: At this point, the driver installation portion of the process is complete.
  16. Connect the USB cable to the printer and the computer. NOTE: Windows will start to Plug and Play the device.
  17. Click Cancel for each Found New Hardware Wizard window that is prompted. NOTE: The number of Found New Hardware Wizard windows prompted by Windows will vary depending on the device plugged into the computer.
  18. In the Printers and Faxes folder, click the hp deskjet 990c printer icon.
  19. Click File . Then click Properties .
  20. Select the Ports tab.
  21. Scroll to USB00x Port and check the checkbox for the port.
  22. Click Close .
Jun 03, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Canon MX328 error display 5b00
Good Day Atzkie!
The error 5B00 in Canon MX328 is a waste ink tank full. The printer detected the number of times that the cartridge has been refilled and counted the volume of the waste ink that flows out from the cartridge to the absorber pads.
You can clear the error on the printer using a MP reset tool. This tool will reset the counter for the waste ink tank.
First of all you will need to download this MP328 tool and run it on your system.
To download, go to http://www.ziddu.com/download/15321203/MP328.exe.html.
Click the download button, then, enter the verification code before hitting another download button.
Click the save button to start downloading.
This is the procedure:
Connect first your printer directly to your computer via usb cable.
1. Make sure the printer is recognized by your computer.
2. Make sure that printer is set as default printer.
Set your printer in to Service Mode
1. Turn off the printer.
2. Press and hold down STOP/RESET button (red circle with inverted triangle)
3. While holding down STOP/RESET button, press and hold down ON button (power on button)
4. Release the STOP/RESET button while holding still the ON button.
5. While holding down ON button, press twice the STOP/RESET button
6. Release the ON button.
(On LCD control panel it will display Service Mode. Wait for a few seconds to display "IDLE" - that is the time when printer is set to Service Mode)
After setting the printer into service mode, run the MP328 tool.
Run MP328 Tool
1. From your download folder. Double click the MP328.exe to display the Service Tool window.
2. Once Service Tool window appear, press the MAIN button.
(It will take sometime to finish the transaction. You will see that the "IDLE" message disappear during the process. You will hear sounds from a series of movement inside the printer. Once finished, it will display "A function was finished") Click the button
3. Press the EEPROM Clear button
(It will take only a few seconds to finished the process)
3. Lastly, press the EEPROM button
After the procedure has finished, close the service tool window and restart your printer.
On your printer, it will ask you to set the language and country for final setup.
That's it Atzkie, that will fix your 5B00 problem.
If my solution was helpful, please feel free to accept my solution by pressing the YES button.
May 22, 2011 | Canon MP830 All-In-One Printer
Hi, i've installed the hp f380 deskjet driver and get ready to print, but i can't go thru' the printing, message shows: the print spooler service is not running... what can i do?
Your problem is a MS Windows problem.
Try to start the spooler service:
1. press the Windows key (the one with the Windows symbol on it), and simultaneously the R key
2. type: services.msc
3. In the displayed list, locate the "Print spooler" service.
4. Right click on it, in the menu that appears click on "Start"
May 03, 2011 | HP DeskJet F380 All-In-One Printer
Hi I have ESP5210 says paper jam......no paper jammed displaying Error 3533
Hi Carole,
I would request you to open the printer and check inside if there is any paper stuck.
If not, you may need to restart the print spooler services.
Press and hold the Windows sign key on the keyboard and then press R button ( Do not release the windows sign key)
In the command box, type services.msc and that will open services windows and then go to print spooler and click on restart and also make sure there should no print job in queue.
Also make sure your printer is online and set as default.
Hope this helps to solve the issue
Thank you
Gowtam R
Jan 06, 2011 | Office Equipment & Supplies
Printing not possible . message " print spooler service not ready"
As most people run Windows on their computer, I will describe how the printing setup works on that operating system. The *nix and Mac operating systems differ slightly in the details but verall are set up similar.
There are two parts to the print dialog box on Windows. The first of these is part of the Windows API (Application Programming Interface). The API is a set of common code pieces that are held in the various DLL (Dynamic Link Library) files that are part of the Windows operating system. Any Windows program can (and should) call the API to perform common functions such as displaying the Print Dialog box so that it will work the same way in all programs and not have different options in different places the way the print option did back in DOS program days. The Print Dialog API also provides a common interface allowing all programs access to the same set of printer drivers rather than printer manufacturers having to create driver software for their printer for each individual program that wanted to use it.
The printer drivers are the other half of the print dialog. There are several different languages that different printers understand that they use to control how the page prints (eg. PCL5 and Postscript). The printer driver instructs the Print API as to how to translate the standard internal print format that the operating system understands into the custom markup language that the specific printer understands. It also adjusts the options that the Print dialog displays to reflect the options offered by the specific printer.
An individual computer may have no printers installed, it may have one local printer, it may have access to several printers over a network, it may even be set up to print to PDF or preformatted print file. Where more than one "printer" is defined one of them is designated the default printer which means that it is the one that displays its details in the print dialog when it first appears.
The operating system keeps track of the default printer and identifies that printer to the various programs on the computer. This allows the programs to pass an extra parameter to the print API telling it to print directly to the default printer without displaying the print dialog first. Many programs have two different print options - a menu entry that displays the print dialog and a toolbar fast print button that sends direct to the default printer.okay another one is
A print spooler is software that temporarily stores print jobs on the computer hard disk or in memory until the printer is ready to print them. If you've been waiting an unusually long time for a document to print, or if you see an error message about the print spooler, spooler subsystem, or spooler resources, you might need to change and then restart the Print Spooler service on your computer.
To do this, we recommend that you save your work, and then restart the computer to restart the Print Spooler service. If you don't want to restart the computer, try these steps instead.
To change or restart the Print Spooler service
You must be logged on as an administrator to perform these steps.
  1. Open Administrative Tools by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Administrative Tools.
  2. Double-click Services. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Right-click the Print Spooler service, and then click Properties.
Dec 19, 2010 | Office Equipment & Supplies
Printer properties cannot be displayed. The print spooler service is not running
The printer connected to your Windows computer works with the help of drivers. Drivers are the link between the printer and the Operating System. Problems with some of the drivers (or the printer driver itself) can cause the printer properties cannot be displayed issue. Users facing this problem are suggested to check the drivers installed on the system using Device Manager, and if the printer or any other drivers are found to be incompatible or fake, they will have to be replaced to solve the problem.
Nov 11, 2010 | HP Officejet Pro 8000 Wireless InkJet...
How do i reset a canon LBP 2410, All the printer is doing is printing blank pages.
you can enter the service mode by going to the printer properties and clicking on display printer status icon thats the one with the ! mark on it. then in the pop up window click on options and then service mode then type *28* and then enter, you are now in service mode. good luck
Oct 08, 2010 | Canon LBP 2410 Laser Printer
I just had my computer serviced and cleared of virus. Now computer wont activate to communicate with printer. I've already tried everything suggested by the display. Computer has recognised the printer but...
delete the printer icon from the printer display window and reinstall.
you will need the driver CD that came with the printer if the printer model is not in the Windows printer install list.
Jan 31, 2010 | Dell 924 All-in-One InkJet Printer
Kyocera FS-C5015N Laser Printer Logo
132 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
