Question about Riccar Sewing Machines
Riccar 8500 sewing machine. The feed dial does not rotate all the way around and stitch length on #5 is too short. The reverse button will not depress.
  • jan_sadie3 Apr 01, 2011
    Unfortunately none of the sites is helpful. I have the manual . It does not address
    my issues. It,s
    a bad manual ! Thank you for trying.
    Brigadier General:
  • 3,513 Answers
I have a riccar 2600 and I can't figure out witch knob makes it sew straight. Please help!!! Thanks, Heather
Perhaps the owner's manual will be helpful:
RICCAR 2600 Instruction Manual
FWIW, it appears that the round dial on the far right is the stitch length selector. The round dial at the top is the zig-zag stitch selector.
Nov 27, 2015 | Riccar Sewing Machines
Machine does not appear to have a button to sew in reverse
try these suggestions
Reduce the stitch length to zero. The machine will stitch in place and form a locked stitch
1) rotate the material and sew over the same stitching. Leave the needle down in the work and raise the presser foot, then turn the fabric around.
2) decrease the stitch length to very small for a few stitches
OR
3) hold the fabric and prevent it from feeding at the beginning and end of a seam, which makes very short stitches
4) stitch about 1/2", raise the needle and presser foot, return the fabric to the beginning position and stitch over the first half inch of seam again. Do the same at the end
Jun 17, 2015 | Euro-Pro Sewing Machines
Buttonholes not sewing evenly on second side
Without know what sewing machine you are using this is a difficult question to provide a firm answer to. It can be an indication of an imbalance in the forward and reverse stitch lengths, which your sewing centre's mechanic should be able to improve for you. This can manifest in either of 2 ways, one where the machine sews one side of the button hole forward and then the other backwards, in this case the length of the second side is different to the first. Machines which sew both sides in the same direction generally lay a basting stitch on the return and then sew the second side of the button hole - in this case the sides will be the same length but offset. Again, depending on the machine, you may have a screw driver slot dial on the front of the free arm of the machine, which you can adjust to increase or decrease the reverse movement of the feed dogs.
Mar 02, 2015 | Sewing Machines
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
How do you sew backwards in a straight line
Difficult to do for long distances as the feed dogs are designed to feed the fabric front to back. But on some Elnas you can turn the stitch length over into the negative on the dial and the machine will sew backwards continuously without using the reversing button.
So check if your machine has this function on the stitch length dial (manual machine obviously, computerised machine is not going to have this option).
Why would you need to do it this way, are you quilting/stitching with a large mass on the left of the needle?
Jun 22, 2011 | Sewing Machines
How do I change the stitch length in my Juki LU 563
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Apr 02, 2011 | Ludwig LG8B2 Industrial Sewing Machine
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
I need to lower the feed dog on my 808. The
There may not be an option. Try this - set the stitch length to zero. This should stop the movement of the feed dogs.
Tape an index card over the feed dogs with a hole punched out for the needle to enter and exit.
Feb 20, 2010 | Riccar R552
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
244 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
