Question about Toshiba Satellite A135-S4527 Notebook
97 Toyota camry
Although I did crank it up putting starting fuel in the airflow. It acts as if its going to start and then shuts off.
The injectors are not receiving fuel. Could it be one of the sensors?
I have started it with starter fluid and kept it runing for a while, but now it doesnt want to start again.
Manny
    Master:
  • 397 Answers
It's even starting to sound like a diesel, if you coax a diesel engine into life with starter fluid the blessed thing will never start again without it.
Sorry but you are goig to have to srtrip it and clean it.
Do you have anywhere near you that can recondition the injectors?
Posted on Aug 05, 2008
95 toyota camry engine trouble code 26 means what
Trouble code 26 has a number of reasons:-
Rich Air/Fuel Mixture / Loose Ground, Injector or Circuit, Fuel Pressure, Ignition System, Coolant Temp. Sensor (CTS), Airflow Meter (MAF), Vacuum Sensor (MAP), Heated Oxygen Sensor (HO2S) or Circuit, Cold Start Injector or Circuit,Compression Pressure, Electronic Control Module malfunction (ECM PCM)
Oct 21, 2014 | Engines & Components for Toyota 4Runner
How I reset the new computer for toyota camry 97 6 cyl ?
need to ck y first spark , fuel presure and engine compresion, and ck timing that are te esencials to make engine work after ck for injector pulse
Sep 02, 2014 | Cars & Trucks
97 camry will not start
believe they have a reset on inner rear fender or possible bad wire
Feb 20, 2014 | 1997 Toyota Camry
Oil smells like gas
check the pvc system it\'s designed to suck the blowby out
Jan 30, 2014 | Toyota Camry Cars & Trucks
1996 Toyota Camry. After the car gets up to
check for fuel leaks, fuel pump fault , faulty pump line on the car. When you had stopped the fuel within the system may be draining off and the fuel pump is not holding on well. check this out
Jun 30, 2010 | 1996 Toyota Camry
2000 Toyota Camry did not start on first try - yellow symbol
Hard to say what it is without testing so I 'm gonna give you a list of things you or a repair shop can check out:
SYMPTOM :NO CRANK
Battery,battery cables,ignition switch, neutral safety switch, starter relay, starter.
SYMPTOM: CRANK NO START
MAKE SURE TIMING BELT DIDN'T BREAK OR SKIP A TOOTH,STARTER current draw test , coil, coil pack, ignition module( only if no spark at the plug wires) fuel pump relay, fuel pump, injector module and drives, fuel pressure regulator.
This year Camry is a good year. Very little problems except annoying EVAP system. TIMING BELT SHOULD BE DONE EVERY 60K . ALONG WITH CAM, CRANK, OIL PUMP SEALS AND WATER PUMP.
I recommend taking your car to Sears Auto Center
they are pretty good with this kind of work.
May 11, 2010 | 2000 Toyota Camry
1994 Toyota Camry Won't start.
you should check 3 things. AIr, Fuel, and "spark"
your cars could have many problems. Ignition module, fuel injectors, Mass Airflow Sensor.
You should check into all of these 3 things.
a crank-no start could be many things.
it could even be a cam positions sensors resistance going up when the engine heats up. Cracnk- no start means testing. n like i said
The motor is getting Air, There is Fuel being put into the cylinders, and the Spark plugs are firing.
Mar 17, 2009 | 1994 Toyota Camry
97 Toyota camry
No.
Unfortunately diesel leaves a residue in the lines and on the injectors.
There is only one cure for this, take out the injectors and get them serviced and flush all the fuel lines out with clean gasoline.
Aug 05, 2008 | 1997 Toyota Camry
Toshiba Satellite A135-S4527 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
