Question about ViewSonic VX900 19" LCD Monitor
Connected VGA cable, power cable, turned on and screen worked for about a minute. Made adjustments on screen to calibrate. Worked fine another minute. Powered down. Now when power switch is turned on, NO SIGNAL, is displayed for 10 seconds and then screen goes black. Checked cables with another screen and cables are fine.
  • 11,361 Answers
Does this VX900M version use the wallwart power supply or built-in power supply? Does it do the same when used it with another PC? No signal means it is not getting the video signals from your PC. Wenned to verify if it is PC or monitor problem first.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 01, 2011
Acer Aspire screen goes black every few minutes only when connected to tv
That may be because you have connected the incorrect VGA port to the TV, remember you need a VGA card installed on you PC with the correct cables VGA to RCA cables to get this right.
Feb 22, 2013 | Acer Aspire Computers & Internet
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
The monitor will run fine for awhile, then the screen will just go blank, this seems to happen with the DVI cable connected to our two desktops with good video cards. I've been using it all week connected...
Check the monitor's internal setup program.
Some monitors have a preset for idle timeout. Of course, as long as you're using the computer, this feature should not be activated and the timer should start over each time you perform any activity on the monitor.
If this is the problem, it should be a simple matter to turn off the time-out feature or set the time to a very high number so that it seldom (if ever) takes effect.
Jan 01, 2010 | Sceptre x22wg Gamer Monitor
My monitor won't turn back on after a reboot, no on light, worked fine prior
check with the power cable or the video cable is connected correctly in the motherboard VGA or if you have graphics card connect the video cable of the monitor to the graphics card VGA slot.
Oct 20, 2009 | LG Flatron L1710S 17" LCD Monitor
No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Jan 26, 2009 | Computers & Internet
ViewSonic VX900 19" LCD Monitor Logo
59 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
